603,321 active members*
3,406 visitors online*
Results 1 to 7 of 7
    Jun 2012
    Laser to cut 1mm Alu, mild steel, and aluminum
    Great forum guys! I am thinking of building/buying a laser system to cut 1mm Aluminum, mild steel, and acrylic sheets.
    I thought about getting a CO2 laser system that would be versatile and be able to cut the mild steel and acrylic easily. I found out that it would be borderline for the aluminum since it is reflective at the wavelength. Further research showed it is possible to do it at a minimum of 200W with oxygen assist. >400W would be ideal probably.. Looking over several vendor, a reliable laser at that power would be the Synrad firestar f series with their beam delivery solutions maybe.. I need to call them for prices..
    Does these sound right guys? Any other suggestions on how else I should proceed? Any build thread you can recommend?
    Feb 2009
    6028
    Just installed a 400 watt YAG, made by Rofin. Nice set up.
    Sep 2011
    296
    Sounds right.
    Mar 2012
    378
    What kind of cost for a YAG?
    Feb 2009
    6028
    Ours is both hard optic and fiber optic, so the price goes up quite a bit for that option. I think it was ~ 260K.
    Jan 2006
    2985
    A 400W Synrad CO2 laser will run you about $60-80k. That's just the laser, then you need the machine, beam delivery, etc. etc.
    Matt
    Feb 2009
    6028
    Matt is correct. 37k for the mill base, plus all the knick knacks to put it together. Our laser came with full optics, so we didn't have any additions there.
  1. How many watts to cut 1/4 mild steel or aluminum?
    By MetropolisCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-14-2012, 03:19 PM
  2. Replies: 0
    Last Post: 12-07-2011, 09:15 PM
  3. Laser Cut / WaterJet Mild Steel Parts
    By GNS in forum Employment Opportunity
    Last Post: 10-02-2007, 11:00 PM
  4. Mild Steel
    By MBG in forum MetalWork Discussion
    Last Post: 03-09-2007, 11:20 PM
  5. Comparing aluminum extrusion to mild steel
    By coolman in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 12-10-2004, 04:19 PM
