603,330 active members*
4,036 visitors online*
    Mar 2004
    1147
    Laser Cut Steel
    I am thinking about getting some parts laser cut.. I want to use them with my NSK and IGUS linear bearings to make a router table.. I have seen some people here mention they got their frames laser cut. i was wondering about the details?
    I am thinking 1/4" or 3/8" steel plate.. Lots of holes, as the linear guides have many mounting screws.
    How accurate is laser cutting? How expensive for just a few parts? like less than 4x4' of plate.
    anyone here want to quote such a job? i am in chicago.
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    May 2004
    7
    Our company buys a number of parts made mostly from 1/4" P&O. Being from Chicago I'm sure there are plenty of laser shops around. We often request hole size tolerances of plus or minus .002 and are never disappointed. Hole finishes are usually very nice with only a light layer of scale (if the parts aren't cut with nitrogen). I'm not very familiar with cutting materials other than steel. To cut up a plate that small in those quantities you could easily spend $200 to $400, depending on the parts of course.
    Jason
    Apr 2003
    1873
    This fellow is a well equiped with good equipment, from a quote I received from him I felt he is quite reasonable.
    His name is Jim Hall
    http://www.lazerimagez.com/
  1. feedback isolator for laser
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-14-2007, 03:34 PM
  2. BT30 taper spindle to cut tool steel?
    By grantmi1 in forum MetalWork Discussion
    Last Post: 05-31-2005, 05:02 PM
  3. example laser cut
    Last Post: 03-22-2005, 10:24 PM
  4. Video of CNC laser cutting steel. Way Cool
    By RotarySMP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-07-2004, 01:56 AM
  5. How do I cut steel?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 07-01-2004, 04:49 AM
