603,924 active members*
3,987 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Thunder Laser > Laser cutter software RDworks v8 tutorial 09 How to Copy Objects Quickly from Thunder
    Hi guys, this is ken from Thunderlaser. Some laser cutter users may use their machines tor to customize some special items and they don’t need to make many copies. But for some factory users, they may need to cut/engrave the same jobs all the day round. So, if we want to engrave many of this object, how can we copy it?
    First, let’s select the object, and then click Draw/Copy Matrix.
    Then input X quantity and Y quantity. Then set the distance between each object. Click ok.
    Now we have 8 copies.
    That’s all for today. See youhttp://www.thunderlaser.com/video/ho...s-quickly.html
    Re: Laser cutter software RDworks v8 tutorial 09 How to Copy Objects Quickly from Thu
  1. Replies: 2
    Last Post: 08-19-2017, 09:16 AM
  2. Replies: 1
    Last Post: 12-30-2015, 08:35 AM
  3. Replies: 1
    Last Post: 12-30-2015, 08:16 AM
  4. Laser cutter software RDworks v8 tutorial 04 How to Align Objects
    By AmyThunderlaser in forum Thunder Laser
    Last Post: 12-30-2015, 08:15 AM
  5. Laser cutter software RDworks v8 tutorial 05 How to Flip an Object
    Last Post: 12-30-2015, 08:14 AM
