587,262 active members*
3,334 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Laser Cutting Engraving Machine Laser Cutter 1400*900mm
Results 1 to 1 of 1
    cnc_laser Guest
    Talking Laser Cutting Engraving Machine Laser Cutter 1400*900mm
    Standard Specification:
    Control system: DSP
    Working size: 55"x35"(1400mm x 900mm) with unlimited length design.
    Laser tube type: Co2 Glass sealed laser tube
    Laser power: 80W/100W
    Driver type: Micro Stepping Motor
    Max speed: 1000mm/s
    Resolution: 2500 DPI
    Location precision: 0.01mm
    PC Interface: USB2.0 and USB Disk
    Software: Lasermate
    Image form: HPGL, BMP, GIF, JPG, JPEG, DXF, DST, AI
    Warranty: 12 Months (3 months for Laser tube and mirrors)
    Machine Dimension(L/W/H): 2040*1460*1070(mm)
    Package Dimension(L/W/H): 2200* 2000*1260 (mm)
    Package: Standard Wooden case for export
    N.W. : 380KG
    G.W. : 500KG
    Standard accessories:
    Laser Engraving software Package (English Version)
    User Manual (CD)
    Industry water cooling system
    Air exhaust fan
    Air Pump
    Communication cable
    3 Reflect optics (installed in the machine)
    1 Focus optics (installed in the machine)
    1 Laser tube
    Other tools
    Optional accessories:
    Honeycomb
    Upgrade 80W to 100W tube
    More details please go to:
    CM1490 Laser Cutting Machine
  1. CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
    By vksingh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2017, 12:53 PM
  2. Replies: 0
    Last Post: 07-05-2013, 08:44 AM
  3. Looking for 600mm x 900mm laser cutter in the USA
    By RCPlaneBuilder in forum Want To Buy...Need help!
    Last Post: 07-12-2012, 09:21 AM
