587,997 active members*
2,159 visitors online*
    May 2015
    Laser engraving ink film / Vintage radio panel
    Hello all!
    I'm trying to replicate an old black radio-panel with white text on a piece of plywood. I originally thought I would engrave it with a CNC-mill and then colour-fill it – but I realized that the white paint would probably bleed into the grain of the plywood, and I don't what type of finish you would use to prevent it. Then I read about these films that you can laminate your piece with, laser-engrave – and your laser-path would be represented with a white imprint which would be visible once you remove the film. Does anyone have any experience with this kind of material?
    Thanks in advance!
    /Jolyon
    Sep 2014
    128
    Re: Laser engraving ink film / Vintage radio panel
    "lamflex"
  1. uv laser cutting and grind for mobile film
    By hanzlaser in forum News Announcements
    Last Post: 02-27-2015, 03:48 PM
  2. uv laser cutting and grind for mobile film
    Last Post: 02-27-2015, 02:40 PM
  3. What is a metal radio tube CO2 laser marking machine?
    By mornlaser2014 in forum News Announcements
    Last Post: 06-19-2014, 03:49 PM
  4. Wet film + Laser plotter = PCB
    By Jake-san in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-31-2010, 02:32 PM
  5. Question about engraving Radio Dials
    By Buzz239 in forum Community Club House
    Last Post: 12-20-2007, 09:12 AM
