Hello,
This is my first post here and I'm looking for a solution for a WEIKI laser bought with a MPC6525 controller.
I have recently bought the laser 600 x 400 mm and I'm looking for a solution with a problem that is not yet solved and because of this the laser is not usable.
I was able to work with the laser for some weeks so I think I'm a little bit familiar with the software Lasercut 5.3.
The laser is connected through a USB interface with a pc. I can control every movement and jogging of the laser from software and on the laser panel, but when after downloading the file, I press the "Start" button in the software or on the laser itself, everything blocks. Nothing is possible anymore and the laser blocks completely. None of the buttons on the panel are working. The only thing I can do is restart the laser machine and everything is back to normal, by that I mean that I can jog, fire the laser and so on but cutting or engraving is not possible. Every time I press the start button to start a job the laser blocks.
If you have a suggestion or if you know what is wrong, I would appreciate telling me the solution very much.
Kind regards, Wendy
