588,551 active members*
5,760 visitors online*
    Jan 2022
    Laser sawtooth finish issue
    Hi All
    Our 2.5KW fiber laser cutter is cutting with bad quality. The finish is a sawtooth finish which looks bad.
    What are the common causes of this?
    I am pretty sure the issue is beyond the cut settings and parameters as we have adjusted them and still no luck.
    Feb 2022
    11
    Re: Laser sawtooth finish issue
    Hello , cutting thin sheet maybe gas flow move the cutting part, if it is not the case, maybe some optic/component is loose inside cutting head machine , and movement produces vibration and sawtooth defect
    Good luck
