587,656 active members*
8,536 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Laser setup - Mirrors aligned, getting two dots with pulse and tape on laser head
Hybrid View
    Jan 2019
    4
    I just finished installing and setting up my new 80W laser. Got all the mirrors aligned, and at all four corners, the laser is hitting the third mirror in the same spot, nearly exactly at the center.
    When I set the laser to the focal length and do a pulse on a piece of wood, I get a center dot, but also a kind of half moon around it.
    I attached tape directly to the laser cutter head and pulsed, and when I pulled off the tape, I had two holes instead of one. (will try to attach pictures to show).
    Any idea what this problem could be? Faulty laser head? Bad focal lens? I'm pretty new to lasers and have not experience this problem before.
    Any help would be greatly appreciated!
    Thanks,
    Tim
    Nov 2008
    643
    Re: Laser setup - Mirrors aligned, getting two dots with pulse and tape on laser head
    I’d look closely at the lens. Then check the burn pattern behind each component starting behind the lens. If you get two burns out of the tube then it’s the tube. Due a quick test fire on painters tape. Be carful not to gunk up the mirrors.
    Jan 2008
    940
    On one of my lasers the final mirror was to far back and the beam would bounce off the side of the lens tube. I had to lower the whole lens mount so the beam coming in would hit higher up on the mirror and the go through the lens straight down. The beam still hits the same spot at all 4 corners but just a little higher
  1. Aligning mirrors on Chinese 60W laser
    By dobrun2004 in forum Redsail Laser
    Last Post: 08-17-2018, 01:58 PM
  2. If there's a laser engraver which no need replace laser tube ,mirrors ?
    By Triumph-support in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-24-2016, 02:51 AM
  3. Gold or Silver Replacement Laser Mirrors
    By Ed3XP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-26-2014, 09:07 AM
  4. About mirrors, laser head
    By Yaro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-18-2014, 01:33 PM
  5. Free CO2 Laser Mirrors
    By twehr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-18-2012, 10:09 AM
