587,832 active members*
3,394 visitors online*
Results 21 to 36 of 36
Threaded View
    Mar 2007
    534
    Laser tube repair?
    Oops!
    I forgot to turn on the water, the ring on the exit mirror detatched and I get a few seconds from cold before the mirror overheats and the beam starts to wander
    40W 70cm tubes are not expensive but it is trying to work, China is on Spring break and this tube is aligned to the optical path. I feel inclined to try and fix it.
    I see two options, either superglue or thermal transfer compound followed by a bandage coated in epoxy resin?
    I will now go and hardwire the pump so I don't have to remember to turn it on :nono:
  1. Laser 150 W RECI laser tube, monster!!!!
    By lamicron in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-13-2014, 06:06 PM
  2. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
  3. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
  4. We supply you CO2 laser machine also laser tube
    By masterandroger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2010, 04:41 AM
  5. 70w laser tube
    By lamicron in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-10-2008, 03:19 PM
