587,401 active members*
3,333 visitors online*
Thread: lasercut
Results 1 to 8 of 8
    Nov 2006
    31
    lasercut
    hi,
    I used lasercut5.3 with laser machine ruijie 1200 X 900 mm, with servodrive panasonic, there is any one for give me all set parameters for well engrave, ( speed start, speed end, space, acc lenght, y acc.......
    thanks
    laurent
    Feb 2008
    8
    Can you tell us what laser tube do you have (80w?), and what material do you want to engrave?
    Maybe I can help you, I have very similar machine.
    Nov 2006
    31
    hi maxxex,
    you have similar machine with servodrive?
    i used this machine for cut and engrave a diferent thickness plexiglas,
    the laser tube is 80 W
    Feb 2008
    8
    No, not with servo drive, I have step motors, but machine size, laser tube and software are the same.
    Is that some enhanced version? Does it also use MPC6515 controller?
    Nov 2006
    31
    no the control card is mpc 6575,
    this just for control servo drive. in software the control is mpc 6515, and all set is same.
    Feb 2008
    8
    Parameters should be the same, for plexiglas (acrylic) engraving I use speed 400, power 27 and line gap of 0.06 and I get good engraving quality, you should be able to run it even faster since you have servo motors. Do you use PWM or Analog signals to control laser?
    Nov 2006
    31
    I use pwm, do is good?
    I would like know the seting in ( work mode, and engrave, in the software, can you send me please
    Feb 2008
    8
    I can't help you much with PWM setting, I can't use them, because when I set to PWM I can't control power when engraving. I use Analog settings.
  1. Lasercut 5.0 and 5.1
    By avetek in forum LaserCut
    Last Post: 12-26-2012, 07:16 AM
  2. LaserCut 5.0
    By edsawen in forum LaserCut
    Last Post: 08-21-2012, 03:08 PM
  3. Need LaserCut 5.0
    By ArturoV in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-19-2009, 08:26 AM
  4. LaserCut 5.0
    By grant_21 in forum Engraving Machines
    Last Post: 04-13-2009, 03:05 PM
  5. Lasercut 5.3 (5.2)
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-18-2009, 03:42 AM
