Originally Posted by
bradlar90
Newbie here too so unfortunately I don't think I'm going to be of much help.
I cut on a honeycomb aluminium bed, which I think is what you're explaining, and the little burn marks on the underside bother me endlessly. Google something called a 'Vector Pin Table', which allows you to support the sheet in different positions and not interfere with the laser at all. They're available commercially, but I've often thought of creating my own. I don't think it would be too difficult.
Occasionally I'll make a "ghetto" vector pin table by engraving what I'm going to cut on a piece of card and then strategically placing small blocks of MDF on the card staying well away from the engraved lines. I then place the sheet to be cut on top of these blocks and cut out the design. You have to get a bit creative with focusing and aligning the workpieces but in the end the part and the leftover sheet should be supported and stay in place.
Can I ask, it sounds like you've been engraving without the use of a honeycomb table? What is the sheet sitting on when you do this?
