Re: last turret position Fanuc
hy duenasg ain't it possible to use a more distant home position, where to index the turret safe ?
i don't know fanuc codes for cw, ccw or shoterts path, as for that i think drdos can help you
few years ago i created an okuma code for colision proof dynamic indexing, and is able to detect in-between indexing posts, with a particular case for opposed ones (those located at 180*), but that should not be a worry if your turret is odd
if you wish, i will share it, you could get the idea and implement it for fanuc
whatever you do ( macro or ladder ), you will not be covered at the 1st index within the program, as for that you will need a system variable for current turret position, or visual inspection before pressing cycle start / kindly
