603,936 active members*
2,200 visitors online*
Results 1 to 5 of 5
    Jan 2007
    20
    Lathe axis question
    I recently purchased a combo mill / lathe, I have no idea how to use a lathe. I do a lot of mig and tig and thought it would be fun to learn a lathe.
    The question I have is I can see the lathe has a x and y axis, but I cannot find a z axis to center my cutting tool. When I mount my cutting tool to the tool post is it just centered with shims, or is there a way to move on a z axis?
    Thanks for all of your help!
    -Ronnie
    Dec 2003
    24260
    I think you are refering to tool height, usually shimed to centre of the material/stock, the axis on a lathe is X across the face of the chuck, Z through the centre of the chuck to tail stock centre.
    The tool height adjustment depends on the type of tool post.
    Al.
    Albert E.
    Jan 2007
    20
    That is pretty much what I assumed. Thank you for your reply, it was very helpful.
    Keep up the good work all!
    -Ronnie
    May 2005
    2502
    Ronnie, a lot of folks buy a quick change toolpost (QCTP) for their lathes. These have a little screw on the tool holder to vary the tool height. Phase II and others make QCTP's for smaller lathes.
    Best,
    BW
    Jan 2007
    Wink Re centring of cutting tools
    You can always put a centre into the headstock, and then use it as a basis for shimming up the cutter.
    Alternatively you can always try facing off a piece of bar stock. If it leaves a pip on the end, it is too low. If runs clean across then you are OK. If it seem to stick at the centre point of cutting - it is probably too high, as the bottom of the cutter is now trying to push past the pip.
    I'm a relative beginner too.
