603,826 active members*
3,564 visitors online*
Results 1 to 8 of 8
    May 2006
    214
    Lathe Circular Interpolation C axis
    Nakamura TW10 Fanuc 18T
    Trying to save set up time. Very low volume job.
    One of the operation require a .625 rough hole. I'll like to use a .5 dia. End mill already in the machine.
    How do I interpolate to make a .5 end mill cut a .625 diameter hole.
    This is how I'm planning on doing it:
    Z0.0 is face of material.
    After I engage C axis....
    G and orientation codes...
    G0X.0625Z.1
    G1Z-.250
    C360.F15. or H360.F15.
    I'm trying to make C axis rotate 360 degrees to increase the hole diameter.
    Please advice if this is a good way to do this.
    Can I use X and Y axis like in a machine center instead??? G2 or G3 from the center of the hole??
    Any input will be appreciate.
    Regards.
    Jorge.
    Mar 2003
    2932
    I think the H360. should work. I believe your feedrate will be in degrees per minute, so F15. will take about 24 minutes to make one rev.
    May 2006
    214
    So much for a set up reduction. LOL
    Thanks for ur replay.
    I have a small macro that will take care of the feed rate.
    O9005*
    #[#18] = #2/[[3.1416 * 2 * #7] * #2 /360] / #9*
    M99
    Again. Thank u very much.
    Feb 2006
    1792
    Quote Originally Posted by jorgehrr View Post
    Not possible, though I am not very sure.
    Jul 2010
    Ok I have a very similar issue. I am looking for a formula to calculate feedrate in degrees per minute. Does anyone have anything?
    Mar 2003
    2932
    Quote Originally Posted by steveptrs View Post
    This might help...
    Attached Files Attached Files
    May 2007
    1003
    How long could it possibly take to mount a 5/8 inch drill?
    May 2007
    1003
    Quote Originally Posted by dcoupar View Post
    This might help...
    Thanks for the link. I have a couple old jobs I would like to try using these formulas on. Just to see how close my guesstimates are.
  1. circular interpolation
    By pmesilver in forum Mach Mill
    Last Post: 04-10-2010, 01:20 PM
  2. Circular Interpolation
    By Deadwood in forum Mach Software (ArtSoft software)
    Last Post: 01-11-2009, 09:35 PM
  3. circular interpolation
    By sqatch in forum Dolphin CAD/CAM
    Last Post: 02-11-2008, 07:02 AM
  4. Circular interpolation problem
    By L. Sakthivel in forum Fanuc
    Last Post: 10-17-2007, 08:26 AM
  5. question about circular interpolation
    By warpedmephisto in forum Benchtop Machines
    Last Post: 03-22-2006, 11:51 PM
