603,958 active members*
1,973 visitors online*
    Oct 2006
    69
    Lathe code idea for Z
    I got the lathe attachment done for the machine and it performs well with the exception of the motor being a little underpowered. I wondering if anyone has done this yet. I was struggling with drawing the clock arbors and the Z code generation. If the stepover settings for tools is the same thing as the stepdown for Z then you should be able to swap the Z cable for the Y and trick the machine so there would be no need to find & replace code with notepad. Always appreciate the feedback here.
    Mar 2006
    427
    Rather than switching out cables each time why not just make two different profiles. One for milling and one for lathe. Then all you would have to do is switch the pins and direction once and open the profile for the different operations.
  1. CNC Lathe G code G73 / G83
    By nelsonrb4 in forum G-Code Programing
    Last Post: 06-06-2022, 11:44 AM
  2. CRAZY LATHE IDEA
    By KENNETH BROWN in forum Uncategorised MetalWorking Machines
    Last Post: 11-24-2007, 12:29 AM
  3. cam to g-code for cnc lathe
    By slow_rider in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2006, 07:16 PM
  4. CNC Lathe Threading G-Code HELP>>>>
    By vtech99 in forum Coding
    Last Post: 08-26-2006, 09:30 AM
  5. fanuc 11 lathe g-code
    By bobcor in forum Fanuc
    Last Post: 08-20-2006, 08:16 PM
