Re: Lathe hole drilling off center - Pleae help
hello mendez, there are some alignment requirements, for a lathe, so to drill on center :
... spindle low tir ( simple dial indicator )
... chuck ( free chuck ) low tir ( simple dial indicator )
... chuck clamping low tirr ( simple dial indicator on a cilindrical stock clamped inside the chuck )
... S axis paralel to Z axis ( turning something inside the chuck, and check it to be cilindrical)
... S axis coaxial with the tool station ( coax ); this coaxiality test is good to be done on :
...... toolholder ( once in a while, so to check machine alignment )
...... sleeve
...... tool ( machine setup, preparation, whenever needed )
... tool station is rigid during cutting ( 2 dials, at 90*, on the tool during cutting )
is this ok ? do you need more details ? kindlly
