603,935 active members*
3,121 visitors online*
Results 1 to 5 of 5
    Dec 2003
    24260
    Lathe programmers - Diameter config?
    I am setting up some Lathe software around a Galil controller and would just like to confirm issues when setting up for Diameter programming.
    Part is programmed in diameter.
    Tool moves radius value, (half programmed value).
    Display indicates actual/radius position value.
    Yeah or nay to the above?
    Al.
    Albert E.
    Dec 2003
    24260
    .......Hmm 61 views and no one is a Lathe programmer?
    Al.
    Albert E.
    Mar 2012
    52
    I would say YEAH you correct, tool moves as you stated
    screen could display either radius or dia or even possibly machines absolute
    possision value. not quite sure with this controler
    Dec 2003
    24260
    Quote Originally Posted by john robertson View Post
    Thanks, I am writing the code so I can make it whatever.
    I just wanted to confirm the norm.
    Al.
    Albert E.
    May 2010
    290
    Yay......readout is diameter, also.
  1. Replies: 3
    Last Post: 08-18-2010, 01:11 PM
  2. Lathe Diameter or Radius
    By davidperry3 in forum Tormach Personal CNC Mill
    Last Post: 12-24-2009, 06:18 PM
  3. How big a piece (diameter) can a 7x lathe turn?
    By Nelson_2008 in forum Mini Lathe
    Last Post: 03-04-2009, 04:18 PM
  4. CNC Mill/Lathe and Programmers
    By PhilaThomps in forum Employment Opportunity
    Last Post: 08-26-2008, 02:16 PM
  5. Inexpensive CNC lathe for 2-3" diameter?
    By squale in forum MetalWork Discussion
    Last Post: 11-08-2007, 10:00 PM
