587,974 active members*
4,449 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Lathe Spinde runout . Is 0.0005" too bad?
    Jan 2016
    4
    Hi All
    I just scored this almost brand new AL-336D lathe for an amazing price.
    I hired a crane to pickup and deliver my machine. The dude insisted and we ended up lifting by the spindle / bed webbing.
    I didn't have time to remove the DRO and didn't want to damage the scales... There is no lifting point in those lathes at all...
    Compared to an AL960 from Taiwan, the quality of my lathe is a joke, but for the price...
    Please let me know if I have too much runout.
    https://www.youtube.com/watch?v=hmzLbu4jhtU
    https://www.youtube.com/watch?v=TDjocgl0sKU
    https://www.youtube.com/watch?v=-ymhXPmFTPo
    Also do you think the fact that we lifted by the spindle could have damaged the spindle / bearings?
    Thanks guys!!
    Dec 2013
    5716
    Re: Lathe Spinde runout . Is 0.0005" too bad?
    You are not measuring spindle runout with that setup. You are measuring chuck body runout, which is well within reason, and has no effect at all on your parts. To measure spindle runout, you have to remove the chuck, and measure the spindle nose.
    Lifting the lathe by the spindle is not a bad thing, more than adequate strength in that area, at least on smaller lathes. I normally lift by put a strap through the hole in the bed then use a 2x4 as a cross piece.
    Jan 2016
    4
    Quote Originally Posted by Jim Dawson View Post
    Thanks Jim
    I ll remove the chuck and check the spindle Tonight.
    The guy lifted through the hole first then the spindle came 2nd. It was a 15 degrees angle... Didnt pull both at the same time.
    Well I guess those lathes arent that heavy
    Cheers
    Alex
  1. Tapered roller bearing runout on mini lathe
    By zoltank in forum Benchtop Machines
    Last Post: 05-19-2015, 09:08 PM
  2. Anybody knows if PP will ever support 0.0005" step rate?
    By CNC-Dude in forum Tormach PathPilot™
    Last Post: 04-01-2015, 10:13 AM
  3. What's a typical number for bore runout for a 6" rotary table?
    By Nelson_2008 in forum Benchtop Machines
    Last Post: 07-24-2012, 01:46 PM
  4. runout on drilled and reamed hole in lathe
    By photomankc in forum Benchtop Machines
    Last Post: 06-28-2012, 06:21 PM
  5. trying to cut 0.0005" stainless
    By lagfish in forum MetalWork Discussion
    Last Post: 02-03-2011, 07:07 AM
