Originally Posted by
MikeA
I have a CNC Mill, Servo II controller, Mastercam V9. I am trying to basically use the mill for a lathe type operation (don't judge, I have my reasons). I want to limit moves to X and Z axis only, lathe tool horizontal in vise. The problem obviously is swapping axis either in the cut file or in mastercam is not giving me proper results. The controller uses I,J commands for arcs in the X and Y and I,K commands in Z axis. Is there a way to trick Mastercam into simply following a contour line in the X,Z axis which is not a toolpath? Any thoughts?
Post it in X,Y and batch edit all the Ys to Zs and Js to Ks
You may have to add a G17, 18, or 19 to change the arc plane
Apparently I don't know anything, so please verify my suggestions with my wife.
