Re: lathe - updated variable list
Originally Posted by
tea hole
Your first link/post is more relevant since it's a P300 spec list whereas the other one lists it as from 2008. The P300 is only a couple years old
i also seen that 2nd one looks nicer, but it lacks content ... come on, does not this always happen ? bling-bling without a thing
VBZOZ >>>
this is encoder origin, also read only ... these origins were in system parameter 2, before last osp update ... now i can't find them ; how do you use VBZOZ ?
How'd you end up finding that?
in this thread : http://www.cnczone.com/forums/okuma/...-sequence.html
@ post 6, mr Wizard shared some LT200MY-P200.txt, that i did not have time to fully get into ... i opened it and i saw "VORD" ... i don't know what it means, so i searched on google, and i found that list ... and i thought to share
also i was thinking you will appear here, because i have noticed your affinity for variables
Tarox
I would also like to see example with some variable as i have no idea how to use them. Thank you.
i also thought that at the begining ... maybe i am wrong, but is better to ask, if you have doubts when you do what you must, than learn variables that solve situations you do not hit into
i guess if you do that, it can spare a lot of time, by learning only what you need ...
also consider taking advise for someone that knows variables verry well tea hole seems nice ... you may find someone knowing, for example, a lot of stuff about variables, and teach you all those, and at the end, you will discover that you did not need that
better learn what you need, step by step, as you advance, instead of general stuff ... ask me if i have read the manuals ! no ...
also, sometimes you may not even think to ask about something that can be done in a easier manner ... this is experience ... so, when you ask something, you may receive an answer that will change your perspective and give you a better solution ... mr Wizard ( OkumaWiz ), for example, is such an advisor
besides mr Wizard, there are superheroes ready to fly & help anytime
