588,644 active members*
4,798 visitors online*
Results 1 to 5 of 5
    Feb 2011
    Layout For Uneven Surface
    Hi there, I have had previous experience using a vinyl cutter in the past and was looking at getting into some work with a laser engraver.
    I was wondering when using a co2 engraver with corel or adobe or whatever software is supplied. How does it work when cutting on an uneven surface.
    Ideally a person probably would like NOT to do this however I'm sure it happens time time....how does the machine compensate for that?
    Do you have to set it up in the software? or does the machine auto focus with its lense? Does that cause the image/pattern to be distorted? Just wondering how that works?
    Thanks!
    Jul 2008
    776
    Depend from what you mean UNEVEN. If it's 1-2 mm - you don't need compensation at all, as laser focus allowed cut/engrave slightly out of focus. If you talk about bigger change - up to 5 mm - possible solution is multi pass cutting with different focusing ofr each pass.
    Feb 2011
    Ok I get what your saying....what about say like a half sphere..or anything with some sort of arc...I guess ideally a person would have a rotary attachment for such a thing?
    I guess an extreme example would be lets say the inside of a stainless dog dish (bowl) even a shape of such flipped upside down
    Jul 2008
    776
    General: of course if you have some kind of arc - you need rotary.
    Dog dish - I afraid you need NdYag laser to engrave on it.
    Feb 2011
    Ok! Thanks for the response...I was thinking there might be some trickery with software to be performed but if it is a limitation of the hardware then I can accept that from a co2 basic machine
    Thanks!
  1. Uneven table compensation
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 09-05-2017, 08:47 AM
  2. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  3. Engraving and uneven surfaces
    By phatjap in forum DIY CNC Router Table Machines
    Last Post: 04-21-2010, 01:11 PM
  4. Uneven finish
    By orbyog in forum Mach Software (ArtSoft software)
    Last Post: 02-05-2010, 08:42 PM
  5. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
