I am using lazy cam to create my tool path from a dxf file from Bobcam. My z is always coming out on 60 before plasma torch on (m03). Does anyone have any ideas? I am using Lazy Cam in the plasma mode.
John
John
Hey, a question maybe I can answer!!!
I had the same issue.
click on the "layers" tab, then enter your desired height.
at least I think thats how i did it.
In the end I still use sheetcam![]()
Thanks John really simpe fix. Have not been working with Lc long mostly use Bobcadcam. One quick question about sheet cam can you nest in that program?
John
Yep, you can. There is even a tutorial in the program to show you how.
One thing I didn't catch on to right away was how to open different drawings on the same screen. Quite simple though... under the file menu, choose "open new part".
HTH , John
