588,546 active members*
4,649 visitors online*
Results 1 to 6 of 6
    Apr 2005
    236
    Question LB15 with OR-10
    LB15 OSP5000L with OR-10, how can i read in my NC-pgm with VDIN[......] the status of the OR-10 (Auto/Manual, Grip-A Open/Close, Grip-B Open/close........)
    I have make a scan/read pgm VDIN[1100.....1253] and send the data to RS232(CN0) ==>>PC.
    I have send the data twice , frist OR-10 in Auto, second OR-10 in Maunual no diff. in the files!!!
    Also on the Adr. 0000... to ....0020 : the files are the same.
    In the manual i have found 4 Adr. groups:
    20...23 Allocation of input Bit from Robot unit (it's a Byte)
    40...43 " " " " to robot unit
    60...63 " " " " from NC
    70...73 " " " " to NC
    Also is it not possible in the Robot (robot.rbt), use VDIN[??] like R1=VDIN[70].
    We get a ERROR.
    regards
    CNCBOY1
    Apr 2009
    1262
    Sample code
    Here is some sample code for an LR-15 with OR20 robot...this will help give you some food for thought.
    Good luck!
    Main program looks like this:
    G13
    M109
    M91M209 (DOOR INTERLOCK OFF)
    ROBOT O2008
    M02
    Robot programs and subs look like this:
    O1008
    (IF 1ST OFF -LOAD MAT'L 1,& GET MAT'L 2 READY
    IF NOT 1ST OFF -UNLOAD & STOCK PRODUCT 2 & LOAD MAT'L 1)
    N4 IF[R1 EQ 1]N19(JUDGE IF 1ST W'KPIECE<'0'=1ST,1=NOT>)
    N5 R1=1(SETS TO 'NOT 1ST')
    N6 R10=R20(SET COUNTER TO LOT SIZE)
    N7 R10=R10-1 (COUNTDOWN -IN PAIRS)
    N8 ZV0F300E90M84(ZMAX)
    N9 CV0(ARMUP)
    N10 M308M301(HANDA OPEN)
    N11 M307(BPOS)
    N12 CALL O108(MAT'L READY)
    N13 CALL O208(MAT'L LOAD)
    N14 M330(START NC)
    N15 M320(TABLE FORWARD)
    N16 CALL O108(MAT'L READY)
    N17 M321(TABLE REVERSE)
    N18 GOTO N28
    N19 R10=R10-1(COUNTDOWN)
    N20 CALL O308(PRODUCT UNLOAD)
    N21 CALL O208(MAT'L LOAD)
    N22 M330(START NC)
    N23 CALL O408(PRODUCT STOCK)
    N24 M320(TABLE FORWARD)
    IF[R10 EQ 0]N28 (LAST OFF NO PICK UP REQD)
    N24 G4F1 (SEPARATE M320'S)
    N24 G4F.1
    N24 G4F.1
    N25 M320(TABLE FORWARD)
    N26 CALL O108(MAT'L READY)
    N26 G4F.1
    N26 G4F.1
    N26 G4F.1
    N27 M321(TABLE REVERSE)
    N28 CV0(ARMUP)
    N29 M306(APOS)
    N30 ZV4M309(HAND B)
    M02
    O2008(LAST-OFF PRODUCT 2 UNLOAD,REGRIP,& STOCK)
    N0 IF[R10 NE 0]N8(JUDGE IF LAST WORKPIECE IE R10=0=LAST)
    N1 (JOG)
    N2 CALL O308(PRODUCT UNLOAD)
    N3 CV0 (ARMUP,JOG)
    N4 CALL O408(PRODUCT STOCK)
    N5 CV0M88(ARM UP,JOG OFF)
    N6 M349(LOT END,STOP REPEAT OF SCHEDULE PROGRAM)
    N7 R1=0
    N8 M330(START NC)
    M02
    O3008(INITIALISING PROGRAM)
    R1=0
    M330
    M02
    O108(MAT'L READY)
    N1 ZV0F300M301M308(ZMAX,MAX FEED,HANDA OPEN,HANDA)
    N2 M307(BPOS)
    N3 CV1(MR)
    N4 ZV1(Z GRIP POS'N)
    N5 G4F2(SETTLE)
    N6 M300(HANDA CLOSE)
    N7 G4F2 (ENSURE GRIP)
    N8 Z=ZV1+5 F50
    N9 ZV0(Z MAX) F300
    N10 CV0(ARMUP)
    N11 M306(APOS)
    RTS
    O208(MAT'L LOAD)
    N1 M308 M91(HAND A,JOG,DOOR OPEN)
    N2 G4F1(DWELL)
    N3 ZV2(CLEAR JAW FACE POS'N)
    N4 CV2(X0)
    N5 ZV3 F50(FEED TO DEPTH)
    N6 M88(JOG STOP)
    N7 G4F.5(DWELL)
    N8 M83(CHUCK CLOSE)
    N9 G4F1(DWELL)
    N10 M301(HANDA OPEN)
    N11 Z=ZV3+20
    N12 CV0F300(ARM UP,MAX Z FEED)
    N13 M90 (DOOR SHUT)
    RTS
    N1 Z=ZV9+10 CV0M306M309(Z GRIP POS'N,ARM UP,APOS,HANDB)
    N2 CV7M88(X0,JOG STOP)
    N3 ZV9
    N4 M310(HAND B CLOSE)
    N5 G4F1
    N6 M84(CHUCK OPEN)
    N7 G4F1(DWELL)
    N8 Z=ZV9+80(CLEAR JAWS) F100
    N9 F300
    RTS
    O408(PRODUCT STOCK)
    N1 ZV0CV0M309(Z MAX,ARM UP,HANDB)
    M307 (B POS)
    N2 CV8(STOCK POS'N)
    N3 Z=ZV10+3(RAPID TO PALLET)
    N4 ZV10F25(FEED TO PALLET)
    N5 M311(HANDB OPEN)
    N6 ZV0F300(Z MAX)
    RTS
    Apr 2005
    236
    Question LB-15 // OR-10
    Hallo Word
    What we want to do:
    A.SDF
    NFSRT IF [QWERTY EQ 0] N100
    N000 PSELECT A1.min ,,,Q2
    N010 PSELECT A2.min ,,,Q2
    N020 GOTO NFRST
    N100 PSELECT B1.min ,,,Q2
    N110 PSELECT B2.min ,,,Q2
    N120 GOTO NFRST
    M02
    A1.MIN
    $GM-MOTOR-PART-Q1122334455.MIN%
    (PRODUCTNAME: GEAR-1122334455REV.B
    RELEASE DD 20080731)
    V901 = 0 (REWINDER 0=NO 1=YES)
    V902 = 1 (QUANTITY 1---to ---4)
    V910 = 1 (AIR- BLOW 0=NO 1=YES)
    V911 = 0 (M19 )
    V920 = Length of Product
    etc
    CALL ROBST
    NC-LATCH pgm
    M02
    FACTORY1.SSB
    ROBST
    VRRRG[1] = V901 (VAR-1 TO ROBBY OR-10)
    VRRRG[2] = V902
    VRRGR[11] = V911 (M19)
    etc
    RTS
    ROBOT.RBT
    (ROBOT PROGRAM………………bla bla..
    IF [R11 EQ 0] NNM 19
    M19
    NNM19 ZV10
    N… (GRIP A UNCLAMP)
    M02
    So what we want to make is a HEAD-PGM for each diff. products (to switch quickly) and there is in written all thinks.
    Airblow NO/YES; M19 NO/YES; Length of Product for take en place robby, set security-place …etc, Work with rewinder. Etc……
    Then the Head-pgm put it into the OR-10.
    But for a good sequence start at the morning we (robby) must know is there a product in grip A and / of B?. Is there a product in the LB15?
    So that way I want to know , how to read switch Open/Close Grip-A , Grip-B, Chuck Open/Close……….
    In a other thread I have put the question about all VDIN and VDOUT’s please read it.
    Is there somebody to tell me about the parm In the OR-10 manual i have found 4 Adr. groups:
    Have someone this information????????????
    Our PGM is ready, it works without the care what we want to have from the inputs!!!!
    Rg
    CNCBOY1
    Apr 2005
    236
    Question
    Quote Originally Posted by OkumaWiz View Post
    Good luck!
    G13
    M109
    ROBOT O2008
    M02
    O1008
    N8 ZV0F300E90M84(ZMAX) <<<<<<<<<==============
    N9 CV0(ARMUP)
    N5 M311(HANDB OPEN)
    N6 ZV0F300(Z MAX)
    RTS
    Hallo
    What means:
    Apr 2009
    1262
    VDIN's can not be read from the robot. I think you need to look in a different section of your manual about the I/O for the robot for if I remember correctly, they start with R801, etc.
    You can check the chuck switches and the gripper conditions using these registers and make your program "smart" by using them.
    I'm going from memory without the manuals , and it's been 5+ years since I've done this, so forgive me if I can't give you exact registers to look at - they are in the back of your robot book.
    I think the e90 caps off the rapid rate of the robot to 90&#37; of full speed.
    Apr 2005
    236
    Question R801 and up
    Hallo OkumaWiz
    """" I think you need to look in a different section of your manual about the I/O for the robot for if I remember correctly, they start with R801, etc."""""
    About the R801 etc. is nothing written in all off my manuals.
    We have R1...R47 for write/read and R48 , R49 only read.
    rg
    CNCBOY1
    <div align='center'><strike><b><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->&#33;&#33;&#33;&#33;....JA....WIR....LERNEN....NI E....AUS....&#33;&#33;&#33;&#33;<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--></b></strike></div>
  1. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  2. Chip conveyor for LB15
    By cad01 in forum Okuma
    Last Post: 12-10-2011, 05:11 AM
  3. OKUMA LB15 reviews
    By WGJ in forum Okuma
    Last Post: 11-12-2009, 11:33 PM
  4. Okuma lb15
    By firepoker1965 in forum Okuma
    Last Post: 09-23-2009, 02:01 PM
  5. Video on LB15
    By beartrax in forum Okuma
    Last Post: 08-27-2008, 04:04 AM
