603,394 active members*
3,198 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > LB15 OSP 5000L controller thread operations
    Mar 2004
    185
    Hi all,
    Anyone running a Okuma LB15 with OSP 5000L controller that can help with threading cycle gcode
    I have managed to get threading code to run with the g33 or the G71 code
    BUT !!!!
    only with the "DRY RUN" switch on. Why could this be ?
    Anyone ?
    And of course i cant actually use it with the switch on as the feed rate is at rapids ..
    both Gcodes below,
    **********works only with " dry run " switch on **********
    (Thread test)
    N181 M1
    N183 G0 X500 Z200 M42 S350 T1010
    N184 X120 M08 M03
    N184 G33 X89 Z150 F1.5
    N184 X88
    N184 X87
    N184 X86
    N184 X85
    N184 G0 X500 Z400 M09 M5
    N185 M2
    (TEST G71.MIN)
    N10 G50 S3000
    N11 G0 X500.
    N12 G0 Z500.
    (THREAD1)
    N13 T101010
    N14 G95
    N15 G97 S500 M3 M42
    N16 G0 X62. Z220.
    N17 G0 Z214.5
    N18 G71 X16.15 Z197. D0.32 H1.6 F1.5 M32 M73
    N19 X62. Z220.
    N20 G0 X500.
    N21 G0 Z500.
    N22 M2
    why wont this work with " DRY RUN " switch off
    Thanks all for looking
    Mar 2004
    185
    Re: LB15 OSP 5000L controller thread operations
    Those of you that are following ....
    Was a faulty spindle encoder
    Funny how the controller didn't report an error ...but I guess that's why it stopped at the threading code.
    Also explains why the dry run worked as its not looking for a sensor for feed.
    Cheers everyone for your input .....lol
  1. Okuma LB15 OSP 5000L
    By CNCAndy in forum Mastercam
    Last Post: 01-23-2022, 08:09 PM
  2. Replies: 8
    Last Post: 10-23-2019, 10:29 AM
  3. Okuma LB15 with 5000L error message
    By stude8 in forum Okuma
    Last Post: 07-25-2019, 02:48 PM
  4. Okuma LB-15 OSP 5000L (not the OSP 500L-G)
    By richardtheu in forum Okuma
    Last Post: 08-06-2016, 11:11 PM
  5. Replies: 3
    Last Post: 09-25-2015, 01:52 AM
