As expected, at least the Z-axis of the LC3024 uses a pair of spherical bearings instead of angular contact bearings, and unlike my dinosaur machine, it appears that all axis are designed this way. This time, and for future commercial installations of my own OEM package, there will be a drop in replacement that uses the above referenced bearings without the mickey moused spherical kit with washers etc. While the rest of the mechanics of the LC series of routers is very sound, I'm still surprised that they're employing this method, especially since all it would take is another pair of castings to just do it right. While I will not be selling my own complete package for generic machining applications, I will make these components available to anyone interested, although the bearings will need to be purchased separately.
I should have the first prototypes both assembled and installed in my current application by tomorrow, as it doesn't really take long to setup and program things like this using my own MicroMill code and enough bearings are also in stock for my current applications. A link to photos will also be available on my Facebook album for this machine. Based on a simple visual, comparison, the housing should be a bit stronger than the original, as the original housings for the spherical bearings are cast mystery metal, likely Aluminum as it is non-magnetic. I'll also be sending a set to Techno, as a suggested improvement to their otherwise excellent machines. In terms of strength, it is more likely that the motor mount counterbores will fail than the new design, which is a 1 piece unit, designed to mount with the major diameter facing the motor side.
