587,656 active members*
6,360 visitors online*
Hybrid View
    Jul 2007
    40
    Lead screw set up help
    I have 1/2-10 acme screw and I am having trouble securing it
    On the motor side I have it going through a 1/2 bearing block, have the antibacklash nut secure to X axis and on the other end I have the screw through a mounting flange. I dont have a 5/16 end bearing block to use so I just run the excess through the mounting flange. I have tried using to steel nuts to secure the screw but either its to tight and the screw wont turn
    Any help would be appreciated, my email address is [email protected]
    Feb 2004
    466
    Please post a picture, it would help.
    Feb 2004
    1086
    What are the steel nuts clamping onto? Do you have thrust bearings in your setup? For our lead screw set ups, we recommend a sandwich of thrust bearings around the main bearing block, as shown in this build log from Glacial Wanderer:
    http://www.glacialwanderer.com/_blog..._threads_1.jpg
    http://www.glacialwanderer.com/_blog..._threads_2.jpg
    Best regards,
    Ahren
    CNCRouterParts
  1. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  2. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  3. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  4. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 02:49 PM
  5. Ball Screw and Lead Screw
    Last Post: 11-21-2003, 03:06 PM
