![Quote](images/misc/quote_icon.png)
Originally Posted by
bearwen
Ger 21,
I thought about welding 2 pieces of angle iron together and then set the pipe on top and tack weld the pipe to the angle iron for support the problem I have is bearings how do I build the bearing races to ride on the pipe I need to have support of the bearings in the x,y,and z directions correct they cant just ride on top and both sides cause then the gantry could lift as you lower the z axis correct I thought about the jgro type bearings but with the supported tube as I mentioned but is the jgro bearing any good or is there a better DIY way?
I would just use steel channel if you are going to weld it. I used AL channel bolted to the torsion box bed for my pipe supports and there is absolutely no flex in the pipes.
See Here
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
