603,978 active members*
2,441 visitors online*
IndustryArena Forum: Leadshine
Page 2 of 8 1234
Threads 21 to 40 of 155
Discuss Leadshine stepper/servo drives, motors, and controls here!
  1. Red LED alert
    Started by Georgie, 03-30-2022 08:51 PM
    axis, capable, carrying, controller, red
    03-30-2022, 08:51 PM Go to last post
  2. Leadshine technical support available on CNCzone.com
    Started by Leadshine, 05-28-2015 09:44 AM
    3 Pages
    1 2 3
    12-02-2021, 04:36 AM Go to last post
  3. MX4660 Estop wiring
    Started by TMToronto, 06-23-2021 01:44 PM
    button, estop, masso, mx4660, pins
    10-05-2021, 03:54 PM Go to last post
  4. MX4660 shunt regulator option
    Started by TMToronto, 07-01-2021 04:11 PM
    10-05-2021, 03:24 PM Go to last post
  5. Problem with MX4660 Fault output on DB25 PIN #15
    Started by TMToronto, 10-03-2021 01:27 AM
    cnc, fault, forum, output, pin
    10-05-2021, 08:54 AM Go to last post
    07-06-2021, 11:59 AM Go to last post
  6. chain leadshine fault outputs?
    Started by Janosch89, 05-20-2021 01:31 PM
    06-15-2021, 12:57 AM Go to last post
  7. mx4660 doesn't communicate with ESS and mach3
    Started by Bigtoe, 06-03-2021 07:43 PM
    cnc, lights, mach3, motor, mx4660
    06-03-2021, 07:43 PM Go to last post
    06-02-2021, 02:53 PM Go to last post
  8. noise?
    Started by Janosch89, 04-20-2021 09:30 PM
    05-17-2021, 02:02 PM Go to last post
  9. Alarm wiring on Rnr motion card (Red)
    Started by trivalb, 05-09-2021 03:58 PM
    24v, alarm, alarm+, driver, gnd
    05-10-2021, 11:13 AM Go to last post
  10. DM542? Discontinued?
    Started by LazyMan, 08-15-2015 10:35 PM
    discontinued, dm542, economical, leadshine, website
    03-01-2021, 07:19 AM Go to last post
  11. Need help to calculate motor size needed.
    Started by jimskeet, 01-29-2021 11:13 AM
    axis, cnc, motor, motors, torque
    02-18-2021, 11:29 PM Go to last post
  12. Help with HBS507 drives!!
    Started by MOCOMAX, 02-03-2021 04:16 PM
    drives, i’m, motor, wiring, working
    02-03-2021, 04:16 PM Go to last post
  13. Debug Lead
    Started by boydage, 01-12-2021 07:01 AM
    software, usb, lead, rj11, remember
    01-12-2021, 09:38 AM Go to last post
  14. HBS1108S Documentation and support issues
    Started by mccafferty, 12-22-2020 04:02 PM
    documentation, hbs1108s, leadshine, software, support
    12-22-2020, 04:02 PM Go to last post
    12-21-2020, 03:02 AM Go to last post
  15. wiring spindle to mx4660
    Started by jlroch, 07-09-2020 07:05 PM
    10-29-2020, 02:14 AM Go to last post
    10-29-2020, 01:55 AM Go to last post
    09-12-2020, 03:50 PM Go to last post
Page 2 of 8 1234
Forum Information and Options
Users Browsing this Forum
There are currently 5 users browsing this forum. (0 members & 5 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
