588,137 active members*
5,625 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Leadshine 57HS30-60 Stepping motor connection
Results 1 to 5 of 5
    Feb 2010
    I have a question regarding Leadshine 57HS30-60 stepping motor wires. I will use bipolar parallel connection for this motor but I don't have any information on wiring and also no information on Leadshine's website. I have black, green, red, blue, white+black, white+green white+red and white+blue wires.
    Thank you....
    Feb 2010
    No answer from Leadshine
    It is strange that Leadshine's Technical department has not sent a reply since last week. Since I am about to reach end of my project I must have the connection motors and I do not want to make mistake ann burn all the things.
    Quote Originally Posted by dodge ram 2500 View Post
    Thank you....
    Aug 2009
    65
    This seems to indicate that the monochrom wires match with the white+color wire. Should be also simple to verify with an ohm meter as the should show connection.
    As a result you have the individual coils.
    Now you could start with a random pair of coils and connect to the driver.
    The other pair should be isolated to not cause trouble.
    So the first two coils are connected and start testing with low current.
    It seems unlikely to fry something this way.
    In worst case you have the coils from the same phase. That should just cause buzzing instead of turning the motors.
    If it turns you are lucky and have identified two seperate phases.
    If not, the two tested coils are the same phase and you are almost done.
    Label both coils pahse A and the isolated ones are phase B.
    You could then skip the next step.
    When the tested coils were seperate phase coils you mark one coil as A and one as B.
    Remove the B coil and isolating it and switch it with one of the previously isolated ones. Test again wether you got a A or B coil
    Repeat it until you know the A/B phase coils.
    Assuming the color coding should make sense it's likely the solid color wires and the white+color mark the coil orientation and they are all the same.
    Once you have both phases identified connect both A and both B coils.
    Just connect the mono colored wire of one phase coil with the white+color of the seconds coil. Same for the other coil end. The coils should be wired with one of the coils inverted in each phase for parallel connection.
    Test again to see if it works ...
    happy testing ... Peter
    Feb 2010
    Problem solved
    Dear dilbert0815,
    Thank you very much for your very detailed procedure for finding correct wiring but Leadshine has sent a reply to me. They say ;
    A+ ( BLU/WHT + RED/WHT)
    A - ( BLU + RED)
    B+ ( GRN/WHT + BLK/WHT)
    B- ( GRN + BLK)
    If you want to change the rotating derection, just exchange A+ and A-.
    Quote Originally Posted by dilbert0815 View Post
    Aug 2009
    65
    They say ;
    A - ( BLU + RED)
    B- ( GRN + BLK)
    Quite unusual indeed.
    8 wire motors are intended for unipolar drive.
    In that case one of each phase coils is wired reverse as the current direction can not change like in a bipolar setting.
    Would be quite unusual to label the wires as they did.
    I would suggest being carefull even while the information came from the vendor.
    In case you get low torque problems you might have to cross one of the coils per phase contrary to their information.
    Peter
  1. Stepping Motor Required
    By terry32506 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-31-2009, 11:47 PM
  2. Leadshine DM556 stepper motor driver.
    By Kingjamez in forum Stepper Motors / Drives
    Last Post: 08-02-2009, 03:22 PM
  3. Worked Stepping Motor Example
    By purgedsoul in forum Stepper Motors / Drives
    Last Post: 07-28-2008, 02:52 PM
  4. help me in stepping motor
    By ibrahem_mo in forum Mechanical Calculations/Engineering Design
    Last Post: 08-28-2007, 10:22 PM
  5. Where to buy stepping motor
    By birdofcnc in forum Stepper Motors / Drives
    Last Post: 01-13-2006, 12:21 AM
