587,933 active members*
4,415 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Learning blade specifications
Results 1 to 8 of 8
    Apr 2010
    I'm not a machinist, but have been tasked with editing some content that contains specifications for Sawzall blades. My question: What does it mean to have a blade that is 4-6 or 8-12 TPI? That doesn't make sense to me, as other saw blades have a single digit for teeth-per-inch. How can a blade have a range of teeth-per-inch? Or, are 4-6 and 8-12 a different designation?
    Thank you for any info you can provide. --Rick
    Aug 2009
    684
    In what context are you given these figures?
    You would possibly see this format on the machine itself, as a recommendation for a specific thickness or material eg for 2" thick material use a blade 4-6 TPI. Maybe?
    Or maybe a blade with the same tooth profile would have a different TPI depending on blade diameter?
    DP
    Oct 2005
    251
    The pitch alternates. The purpose of this is to allow you saw a wider range of cross sections. I think the rule of thumb is three to four teeth in the cut at any time.
    Dec 2008
    226
    I recently bought a bandsaw blade that was variable pitch... 10-14 tpi... the teeth get closer and farther apart... cuts real nice... don't know if that applies here.
    Nov 2007
    479
    Quote Originally Posted by rtdreep View Post
    Tooth Pitch is always measured in the number of teeth per inch---from tip of tooth to tip of tooth. Variable Tooth blades are indicated by two numbers since the tooth pitch and the gullet depth varies.
    Apr 2010
    Very helpful, thank you!
    Thank you all for your input; it's much appreciated!
    Jan 2007
    1389
    Rick on my band saw I run a 4-6tpi
    the way I understand it is 6 teeth per inch how ever they throw the 4 size in there for clearance, so you have 4 small teeth and 2 big teeth.
    I just got one a bit ago I will check it out and verify
    Jan 2007
    1389
    looked up a better example
    http://www.worldwidesaw.com/faq/
    Variable pitch blades are usually preferred in most applications because of the varying teeth configuration per inch. Beacuse the teeth vary between fine and coarse, sawing harmonics vary, thus vibration and chatter are dampened. Adjusting the blade speed is another way of reducing sawing harmonics problems. Think of a washing machine that speeds up during the spin cycle. At a certain point the rotation of the drum hits "resonance" and the washer want to start walking across the room. Soon the rotation speed increases and the washers stops walking and shaking. You don't want to have your saw hit resonance and stay there.
    Variable pitch blades accomodate a wider range of material cross sections and are particularly useful when cutting rounds and tubing, due to the fact that the top and bottom of the curved workpiece will have a smaller cross section than the middle of a round solid and this is where the harmonics problems tend to be the worst (entering and leaving the workpiece). For tubing and pipe, the top of the material cuts like a solid, then the sides of the tubing cut like thin flat stock.
  1. IKO LWH25 Specifications
    By ViperTX in forum Linear and Rotary Motion
    Last Post: 09-18-2012, 08:57 PM
  2. Replies: 4
    Last Post: 01-02-2009, 10:55 AM
  3. Pipe Specifications
    By rancherbill in forum Material Machining Solutions
    Last Post: 12-06-2006, 10:33 PM
  4. THK HSR20CR specifications?
    By Lucien in forum Linear and Rotary Motion
    Last Post: 04-24-2006, 10:24 AM
  5. Specifications on Various Machines
    By alwayslearning in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2006, 05:32 PM
