I just finished building my CNC and I've been playing around Rhino and MadCAM all day trying to cut a job.
I designed an extruded rectangle in Rhino, wirecut some blocks then filled the holes with new blocks that run halfway the thickness of the part. Here's a pic to give you an idea.
First problem: Each time I try to 3D pocket these holes MadCAM cuts all the way through the object, it doesn't stop at the middle of the thickness where it should stop. Is there a way to make it do that?? What am I doing wrong.
Also, can I edit the number of depth cuts it takes?
Second problem, madCAM put extra corners in my drawing for no reason, all my holes are perfect squares, yet, this is how the simulation looks, how can I fix that?
Here's a pic of some scrap mdf to try out the job, again this isn't square. Anyone knows what I should be doing?
I've had to edit the g-code myself to get the CNC to only cut two layers instead of it going through 6 layers and cutting right through the piece. I'd love to find out what I need to do to delete the extra cutting depths.
oh yes, problem #3, madCAM cuts 1.2mm depth in hole number 1, then move to the next hole, then the next etc... once its got all the holes done it moves back to the first hole and cuts the second pass, then off to the next hole...it takes an eternity to get all 6 passes done.
How do I get it to cut one hole at a time THEN move to the next hole?
