learning to model
Mlinder and I were having this discussion off the forums (forgive us, Paul G ) so I thought it would do more good to try to carry this on in public because I know there are experienced users out there who can clue us "2d'ers" in on doing 3d stuff.
Subject: Mill eXPert Join function (Mlinder)
Anyway, I have been poking around the program and learning what I can without a manual. Coming soon, I’m told.
One of the first things I noticed was the lack of a Join function within the Translate dialog. It was shown in the Tutorial, but not available in the actual program. I contacted Mike about it, and Australia simply removed that function. I notice now in this new patch, that even the tutorial has been revised, so that now one must translate the geometry, then join each and every entity individually. This is a bit backward, don’t you think? Not that I use that function very often, but I do use it (in my 2D program, MasterCAM Router).
HFD's reply
Yes, I noticed that discrepancy between the tutorial and the way things actually were. Maybe it was a buggy function?
In most cases, can you not accomplish more by using the extruded surface function to do the translation? This way you end up with a solid, and there is no need to fool around making surfaces on the sides you are joining?
Mlinder
That's what I did - just use extrude. The only thing is extrude doesn't seem to extrude holes (360 degree arcs). Maybe I'm missing something there.
First you get good, then you get fast. Then grouchiness sets in.
