587,136 active members*
3,581 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Leaving lip on pocket rabbet joints?
Results 1 to 5 of 5
    Dec 2011
    45
    I'm using vectric aspire and a pocket operation to do rabbet joints. I've done a bunch of these on MDF and they came out good but I'm doing plywood now and all of a sudden I've got a .03" lip left between the pocket edge and the profile cut. Definitely not a machine issue, my bit seems fine, kind of clueless why this lip is being left here. Any ideas?
    Attachment 384316
    Attachment 384318
    Dec 2011
    45
    Re: Leaving lip on pocket rabbet joints?
    Upon measuring it seems to have cut the pockets 1/16" to small all the way around. hmm
    Mar 2003
    35538
    What kind of machine is this? Are you climb cutting, or conventional cutting?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2011
    45
    it's my diy router. all the outer profiling in this toolpath was dead on perfect. just these pockets and some of the inside profiling is smaller than intended or shown in aspire. climb cutting. would that cause this? I have thought about switching to conventional
    Mar 2003
    35538
    I can't really tell what the issue is by looking at the pictures.
    If ther's any deflection in your machine, climb cutting can cut smaller than intended.
    Gerry
  1. Finger/Box Joints
    By JerryBurks in forum Uncategorised CAM Discussion
    Last Post: 09-22-2014, 04:15 AM
  2. Dovetail Joints
    By rickwooddsgn in forum Commercial CNC Wood Routers
    Last Post: 09-11-2013, 02:40 AM
  3. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
  4. Joints to fit ALU
    By tcdk in forum DIY CNC Router Table Machines
    Last Post: 05-17-2010, 03:28 PM
