603,347 active members*
3,199 visitors online*
    Mar 2007
    LeBlond Makino
    I'm looking for this part? I need 5. Does anyone know where I can get these?
    It belongs to the turret. Lock nut for tool holder. The diameter is 22mm, 8mm thread, 34mm long. Please PM me.
    Feb 2006
    340
    Unless they are part of some subassembly the tool builder bought and installed then your only source is usually the tool builder. If you can identify it as an after market item, you may be able to find an alternative source. The only other possibility would be someone making these as replacements if they break/fail often enough.
    I feel your pain, I have managed to find some parts from alternative sources for 1/2 to 1/4 the price from the dealer/tool builder. Usually after buying them for full price at least once.
    Mar 2007
    dpuch,
    Thanks for the info. I will give the post more time.
  1. Used Leblond
    By lilguy in forum Uncategorised MetalWorking Machines
    Last Post: 11-12-2007, 06:09 PM
  2. Okuma and Leblond
    By Jagermeister in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2006, 08:45 AM
  3. Leblond Makino (fanuc OM) Problem
    By Masood in forum Fanuc
    Last Post: 09-22-2006, 07:55 AM
