587,465 active members*
3,157 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > LED light guide plate advertising slim light box 3D V-cutting machine
Results 1 to 18 of 18
    CUTCNC Guest
    A significant advantage to LED Light Sheet lies in the production of the Light Guide Plate Sourced for its rigidity and light transmission properties, a clear PMMA
    acrylic is etched with multiple grooves using patented 3D V-cutting technology to create a uniform matrix. This etched matrix acts as a vehicle to transport light from the unit’s embedded LEDs across the entire surface of the panel to deliver homogeneous illumination.
    CUTCNC LED light guide plate advertising slim light box 3D V-cutting machine special tools make the v-groove at the same depth, make sure the same brightness by different distance of lines. Mainly used to make high end advertising light box.
    CUTCNC Guest
    The light guide plate processed by our slim light box engraving machine.
    CUTCNC Guest
    Advantage of thin LED light box
    1.Energy saving up to 50%, high intensity
    2.No electric wave
    3.No RF interference
    4.No such hazard that mercury or lead enters the environment.
    5.Unique Lamp appearance design
    6.Energy-saving and environment-friendly
    7.Leading heat sink design, excellent heat eliminating
    8. No UV or IR radiation
    9.No flashing
    10.robust and long lasting
    11. Replacement for incandescent lamps.
    nokoshun99 Guest
    CUTCNC Guest
    yes, after processed by our V-cutting machine, you just need one or two light batten to make the whole light panel bright. This kind of light box is beautiful and energy saving, it is the trand of future trend.
    CUTCNC Guest
    The structure of LED slim light box
    CUTCNC Guest
    LGP Technology was first produced in order to backlight LCD screens for TV’s and notebook computers. New LED technology has produced brighter more efficient LEDs to incorporate with LGP technology, we are now able to produce lighting fixtures and display boxes wtih high efficiency and longer lifespans.
    May 2012
    The operational life of current white LED lamps is 100,000 hours. the long operational life of an led lamp is a stark contrast to the average life of an bulb. there is no comparison between the cost of LED lights and traditional options. it will be interesting to see what developments are coming for more residential applications of LED lights.
    CUTCNC Guest
    some of our customer create the LED light guide panel applied in residential, it is the same light box, without a advertising film,can be used for lighting.
    CUTCNC Guest
    Picture material of scrolling light box screen generally has three types: backlit film , PP synthetic paper and light cloth.
    Backlit film is the common “photo”. The picture made by backlit film has high definition and high transmittance. But the picture is heavy and price is relatively high. It’s not an ideal choice for scrolling light box.
    PP synthetic paper is PP gum in the market. It’s light and definition can basically meet the basic requirements of scrolling light box. And the price is cheap. So for scrolling light box with no special requirements, it’s generally preferred PP synthetic paper.
    Light clothe has specifications of larger size with low price. But the light transmittance of cloth is not good, and relatively soft, the scrolling effect is worse than other two types of material. However, backlit film and PP synthetic has size limitation, only light clothe can be applied in large-size scrolling light box.
    CUTCNC Guest
    The one or two SMD 3528 LED light strip used in supper slim light box:
    5 meters / roll,
    Voltage DC12V,
    Current of 0.4A,
    Angle 120 °,
    LED quantity: 60pcs/m
    wavelength/color temperature: 620-630
    material: FPC
    Power: 5w/m
    voltage: DC12V
    brightness: 300-500mcd
    CUTCNC Guest
    LGP is a transparent acrylic panel made from pure PMMA resin, on whose bottom face a line matrix is scratched. The light source is installed on its edge(s). It distributes the light coming from the light source evenly over the whole upper face of the acrylic panel. It is a key component to maximize the uniformity of light, to make backlight slim and to reorient the line or dot light source such as fluorescent , decoration lamp or LED to the plate light source.
    Nov 2011
    After compare with our other machines, laser, engraving machine, screen printing, I think your V-cutting is best. Send me e-mail, we talk about the detail
    CUTCNC Guest
    Quote Originally Posted by SteveAndy View Post
    Thanks for your trust, I have send the detail to your e-mail. If you have any questions, contact me freely, Thanks.
    CUTCNC Guest
    1) professional Automatic light guide panels plate drawing lines plotter V cutter groove engraving machine can draw accurate lines, accuracy up to ± 0.05MM.
    2) Light guide effects perfect, astigmatism uniform
    3) high producting efficiency, average drawing line speed 36m ~ 60m. per minute
    4) engraving drawing any graphics, easily revised to meet customer needs
    5) Working continuously 24 hours a day for batch production with panasonic servo motor
    6) solving the problem of uneven thickness of light guide panel plate effectively, automatically adjust the depth of light guide panel plate.
    CUTCNC Guest
    CUTCNC v-cutting machine compare with laser cutting machine:
    1 Good V-groove cutting effect
    2.No burning smell
    3. No dazzling light when working
    4.Low usage cost
  17. #17
    CUTCNC Guest
    Quote Originally Posted by wanglod94 View Post
    hello
    Hi, what can I do for you?
  18. #18
    Using it for advertising and marketing purpose, will be a great option.These lighted signs are energy efficient so budget will never be a problem.
  1. Screen Printing to Process Slim Light Box Light Guide Plate
    By CUTCNC in forum News Announcements
    Last Post: 11-19-2011, 10:20 AM
  2. Common Workmanship to Process Slim Light Box Light Guide Plate
    By CUTCNC in forum Community Club House
    Last Post: 11-19-2011, 10:01 AM
