588,548 active members*
5,389 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Length of Ballscrew and Rails for 1000mm travel?
Results 1 to 6 of 6
    Mar 2005
    269
    Hi guys, i want to purchase the ballscrew machined for 1000mm travel but dont know how much need to be the length of the ballscrew and the rails.
    I want to purchase
    1 x THK Rails with SSR20 for 1000mm travel
    2 x SFU1605 with signle nut for 1000mm travel
    but have a priblem to calculate the final length and how calculate, i think that i need to extract for example from the THK rail the length of the SSR20 Block Bearing.
    the drawing that i will use for machining the ballscrew are this http://www.slidesandballscrews.com/p...ng%20600mm.pdf
    Please help me.
    Sep 2005
    540
    If I read your post correctly I believe the minimum answer is the length of travel + the distance between the mounting blocks of your moving gantry. This assumes that your spindle is mounted in the center of the gantry. You should add something in rail length for error, over run, limit switches, etc.
    Correction: + the width of the gantry, not one half.
    Robert
    Mar 2005
    269
    thanks for your support, and yes the spindle will be in the center
    Feb 2009
    95
    Quote Originally Posted by RTP_Burnsville View Post
    If I read your post correctly I believe the minimum answer is the length of travel + one half the distance between the mounting blocks of your moving gantry. This assumes that your spindle is mounted in the center of the gantry. You should add something in rail length for error, over run, limit switches, etc.
    Robert
    Shouldn't it be full distance - you have one half overrun on each end which makes two halves.
    As for the screw, it can be shorter than the rails depending whether it's possible to mount the supports under the table. but the threaded part must be at least the travel plus the length of the nut.
    But is generally good to leave some spare length for later small modifications.
    Sep 2005
    540
    Robert
    Fixed Typo....
    Mar 2005
    269
    well, for 1000mm length 16mm diameter ball screw are not enough? will be better if purchase 20mm?
    is OK to mix ballscrew diameters in differents axis? later is possible to configure match or any other software to calculate the steps because that?
    Regards
  1. max length of ballscrew
    By stirling in forum Linear and Rotary Motion
    Last Post: 07-19-2019, 11:05 AM
  2. X3 CNC Fusion Y ballscrew length?
    By WOTDesigns in forum Benchtop Machines
    Last Post: 06-22-2011, 02:40 PM
  3. Have ballscrew will travel/how far?
    By lgalla in forum Linear and Rotary Motion
    Last Post: 01-11-2007, 03:39 AM
  4. lead or ballscrew length
    By woodrow in forum Linear and Rotary Motion
    Last Post: 04-25-2006, 05:58 AM
