587,366 active members*
3,649 visitors online*
Results 1 to 10 of 10
    Sep 2007
    200
    limit switch error fool-around
    i'm running emc with a gecko540 and i'm only just ready to start
    but for my lack of information.
    the latency was my first prob but i soon fixed that.
    i then ready the entire HAL instructions because i couldn't find the on button
    anyway the problem i have now is my limit switches they seem to require a different setting each time i turn them on. one day x inversed, y z normal
    the next all inversed. i keep bouncing between emc and the configuration panel and then when i jog it hits the switch and repeats the limit switch error.
    one theory i have is that my config is set for two open switches in parallel and the gecko takes two closed switches in series. i don't know. but it is very erratic .
    Apr 2005
    1778
    The general rule is that you don't want your limit switches wired NO (normally open) and parallel. The rational is that if a wire broke, you wouldn't notice until you ran into a limit switch and it didn't work. One can also come up with a scenario where a circuit with NC switches wired in series could also fail in an unnoticeable manner, but there are fewer points where the circuit could fail in an undetectable manner.
    Alan
    Sep 2007
    200
    why would a limit switch trigger an error at all.
    Apr 2005
    1778
    Quote Originally Posted by draughted View Post
    Because you are not supposed to hit the limit switches. If you hit a limit switch, you have created an error.
    That is why you have to tell emc2 if you are using limit switches as home switches as well. So that it can ignore the limit switch error and treat it as the home switch during a homing operation.
    Alan
    Sep 2007
    200
    ok thanks, however it seems in my ini file that it is all ready set to ignore-limit-switch
    and homing becomes a problem.
    it always sees the first home as an error
    Apr 2005
    1778
    Here is some of the info from my .ini and .hal files.
    From my .ini file
    #+ First axis
    [AXIS_0]
    HOME_OFFSET = -0.1
    HOME_SEARCH_VEL = -1.500
    HOME_LATCH_VEL = 0.250
    HOME_USE_INDEX = NO
    HOME_IGNORE_LIMITS = YES
    HOME_SEQUENCE = 1
    # the same basic info is included in each axis
    ### From my .hal file the pin and signal setup for estop and limits
    # create a signal for the estop loopback
    net estop-ext <= parport.0.pin-10-in-not
    net estop-out <= iocontrol.0.user-enable-out
    net estop-ext => iocontrol.0.emc-enable-in
    # create a signal for the limit switches
    net both-home-x <= parport.0.pin-11-in
    net both-home-y <= parport.0.pin-12-in
    net both-home-z <= parport.0.pin-13-in
    # create a signal for the x home and x limit switches combined
    net both-home-x => axis.0.neg-lim-sw-in axis.0.pos-lim-sw-in axis.0.home-sw-in
    # create a signal for the y home and y limit switches combined
    net both-home-y => axis.1.neg-lim-sw-in axis.1.pos-lim-sw-in axis.1.home-sw-in
    # create a signal for the z home and z limit switches combined
    net both-home-z => axis.2.neg-lim-sw-in axis.2.pos-lim-sw-in axis.2.home-sw-in
    Alan
    Sep 2007
    200
    it is almost too embarising but it seem that i mistakenly labeled the limitswitch terminals in the opposite order to their being wired.
    making the home sequence a shambles when the wrong limit activates.
    Apr 2005
    1778
    Well, at least you discovered what was causing the problem.
    Alan
    Oct 2008
    78
    Don't feel like the Lone Ranger I had cross up the encoders on Y and Z . Just could not figure out why I could change the direction of Y :-)
    Mar 2008
    62
    This is also the case with one of my axes. Always error on the forst Homing after power on. After the first one everything seems to be working as expected.
    Have you goeetn this issue solved?
    regards Chris
  1. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  2. Limit switch Error
    By friklin in forum DIY CNC Router Table Machines
    Last Post: 06-24-2008, 11:14 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
