588,460 active members*
5,023 visitors online*
Results 1 to 5 of 5
    Oct 2005
    29
    Limit Switch Problem
    I have all my limits set to pin 13 on my BOB. 5 volt input. When I set to active high, my limits do not work. When I set my limits to active low, like my home switches, I cannot reset the E stop.
    Oct 2005
    29
    I just noticed that my Manual Limit override is flashing in the Settings screen. I 'm wondering if this is related to my other problem. How do I correct this?
    Sep 2007
    740
    How are your limits wired?
    Oct 2005
    29
    Yes, all my limits switches are working. I have them in series.When I go to diagnostics screen, and trip one of the switches, all three lights go on as expected. I have them set up for 5 volts. Everything seems hooked up correctly, but when I run an axis to the switch, it will not stop. I get no EStop. I have tried active high, active low, to no avail. Like I said, The manual limit override is constantly flashing. Is there a way to reset or turn this off?
    Oct 2005
    29
    I had my limit set incorrectly in the input section of setup. I just didn't scroll down far enough. Thanks for all the help.
  1. Limit switch problem
    By jimini in forum Mach Software (ArtSoft software)
    Last Post: 09-18-2007, 02:49 AM
  2. Mach3 limit switch problem on Ref Home
    By originator in forum Mach Software (ArtSoft software)
    Last Post: 03-13-2006, 03:02 PM
  3. Problem With IH Limit Switch.
    By Willyb in forum Charter Oak Automation Support Forum
    Last Post: 11-07-2005, 12:17 AM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
