587,189 active members*
2,718 visitors online*
Results 1 to 5 of 5
    Sep 2006
    91
    Limit switch triggered
    I have had an IH mill running Mach3 for several years now and it has performed very well.
    After a 3 month break from running the mill, I cranked it up again and started getting a Reset, Limit Switch Triggered, both when the mill was working and when it was just sitting there. I am sure it is some type of noise problem. Any suggestions on how to diagnose this? I wish Mach3 had some type of error log that would give the source of this problem. Does anyone have any suggestions to troubleshoot this?
    Thanks in advance for any suggestions.
    Jim
    Noncarborundum Illigitimus
    Sep 2006
    91
    Re: Limit switch triggered
    I should mention that my debounce in Mach3 is set to 10000, I am using shielded cable and have verified that I have continuity from the cable shield to the common chassis ground.
    Jim
    Jan 2011
    188
    10000 debounce ? that's almost half a second ....
    is the limit switch normally closed to common?
    if so:
    connect a wire jumper from the limit input on the BOB to common
    if the problem persists then it is probably the cable to the computer or the BOB or the computer
    if the problem goes away then it is probably either the limit switch or the limit switch wiring - loose connector, broken wire, etc
    in that case, connect the problem limit switch to the BOB with new wires
    if the problem goes away then it's in the wiring
    if it persists then it may be a bad limit switch
    if nothing helps then it may be an earth ground issue - all cable shields should be tied to one single ground point - no branches and never ground a shield on both ends
    www.signtorch.com
    Sep 2006
    91
    Thanks for your suggestions.
    I can rule out a grounding problem. I have only one ground and no branch circuits.
    I have just one question before I tackle your other suggestions. What is a BOB?
    Jim
    Jan 2006
    58
    Break Out Board
  1. Limit Switch Triggered! IS NOT!!
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2020, 12:18 PM
  2. Replies: 3
    Last Post: 09-30-2013, 08:55 AM
  3. limit switch triggered
    By Claude Boudreau in forum Machines running Mach Software
    Last Post: 04-29-2012, 01:06 PM
  4. limit switch triggered issue
    By 15mgtar in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2009, 09:25 AM
  5. Limit Switch Triggered??
    By H2ODiver in forum Mach Mill
    Last Post: 02-22-2007, 06:48 PM
