603,407 active members*
2,298 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons > Limit switches,can i program them to just stop, and not punch out the E-stop in mach
Results 1 to 6 of 6
    Dec 2008
    446
    Red face Limit switches,can i program them to just stop, and not punch out the E-stop in mach
    Hello.
    I run several of cnc machines at work.. (just started) :P
    And all of them does not punch out the e-stop button when they reach the end of an axis. At least not when I jog.
    Can i fix this in mach?
    And another question, when i run a program. For example a 3d relief. I can run up too 70mm / sec. the axis stop, and on the screen it says "Emergency mode" or something like that.
    Does anyone have a tip?
    Greetings from Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Mar 2003
    35494
    1) Use softlimits.
    2) Sounds like noise is triggering your estop.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2008
    446
    Hello Gerry.
    Thanks for answering.
    1) How do i do that with the softlimit?
    2) I will try to change the cable from the VFD to spindle with one that are shielded (Yes I am a fool to have thought of that before)
    Mar 2003
    35494
    You set up your soft limits to stop just short of the physical limit switches. Watch the homing and limits video here:
    ArtSoft USA - Video Tutorials
    Gerry
    Dec 2008
    446
    Thank you i will come back if i have some more questions
    Dec 2008
    446
    Problem solved!
    works like a charm!
    Thanks again!
  1. Limit switches don't stop the machine
    By dfv in forum Mach Mill
    Last Post: 01-25-2011, 10:22 PM
  2. Got a Gecko G540, now which limit switches and E-Stop?
    By CNC Lurker in forum DIY CNC Router Table Machines
    Last Post: 12-06-2010, 10:13 AM
  3. BOSS 5 Limit switches don't stop movement
    By db427 in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2010, 09:15 PM
  4. DO I need LIMIT SWITCHES or E-stop??
    By max90272 in forum Stepper Motors / Drives
    Last Post: 07-14-2008, 05:45 PM
  5. Limit, Home and E Stop Switches
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 01-17-2007, 04:02 PM
