588,410 active members*
5,377 visitors online*
Thread: Line weight
Results 1 to 5 of 5
    Apr 2003
    89
    Line weight
    Hey Guys
    I'm using Acad 2000 and would like to get a line weight of .25" to similate cutter diamiter in my drawings.
    The largest weight available seems to be 2.11mm.
    So the question is how do I get 1/4" line weight?
    Mar 2003
    6855
    Can you just offset the lines and fill it in with a solid hatch?
    Mar 2003
    35538
    The help file specifically says not to use lineweight to represent an actual width, which is probably why they won't let you do it. If you want to see the offset while you're drawing, use the offset command. If you want it for plotted output, you can get any lineweight you want by using plot styles.
    Gerry
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2003
    416
    Use a polyline (two arcs). You can set the width using pe (polyline edit)
    Apr 2003
    89
    Thanks for all your help guys
    Poly line width has it!
    Now I can draw my parts and use pedit width to make sure my tool paths are doing what there told
  1. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  2. Single Line Fonts
    By A. Shuford in forum Uncategorised CAM Discussion
    Last Post: 11-14-2004, 03:21 PM
  3. Z-AXIZ weight
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 07-01-2004, 10:35 PM
  4. Possible gantry weight problems
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 12-03-2003, 07:29 PM
  5. Tool tables
    By Nimrod in forum Mastercam
    Last Post: 11-24-2003, 09:31 PM
