587,761 active members*
3,103 visitors online*
    Jul 2006
    22
    Question Linear Encoder
    I have a Southwestern Industries Prototrak MX3e system installed on a Knee Mill as a retrofit. I need to replace the liner encoder which reads the X axis movement. The original encoder is the Gage Wheel type and limits my travel in the Y Axis by a few inches because it fairly large. I would like to replace it with a glass scale type or a newall type. As far as I know the machine does not have encoders built onto the servos. I disconnected the gage wheel output to the control and of course no movement. My X axis travel is about 30 inches.
    I was informed a Newall SHG-TT Linear Encoder would work but, I was also informed the encoder needs some sort of "mark" for the Prototrak system to read it. The Newall is pretty expensive and I am looking for something a lot less costly. Any ideas or experiences would be appreciated. My past experience is very limited. Usually I replace parts from the factory and it always cost a small fortune.
    Ken
    Mar 2006
    2712
    We had excellent results with Newall Spherosyn round tube linear encoders. Solved our "lack of feedback" problem on large machines where the Heidenhain glass scales couldn't handle the vibrations. (30 ft. vertical boring mill converted to 4-axis CNC).
    The scale and reader are enclosed in the "reader block" which cancels the vibration. Also, they function in the dirtiest environment.
    Dick Z
    DZASTR
    Mar 2008
    267
    I am using both glass transmissive scales from FRS (way before Heidenhain acquired them) and Adhesive reflective optical tape from Renishaw.
    Both working nicely in their respective environments.
    nishaw tape is applied directly to the machine frame and needs to be protected from envirnoment.
    cost?? Cant remember the price of glass scales.. but renishaw product.. tape by the yard reader about 1200 dollars.
  1. linear encoder
    By valenti in forum CNC Machine Related Electronics
    Last Post: 08-24-2010, 05:23 PM
  2. DRO linear encoder for uhu/hp uhu
    By rokag3 in forum UHU Servo Controllers
    Last Post: 03-09-2009, 01:05 PM
  3. Linear Encoder Information
    By jlaiken2 in forum Uncategorised MetalWorking Machines
    Last Post: 07-29-2008, 02:23 AM
  4. Linear Encoder Question
    By Verboten in forum Linear and Rotary Motion
    Last Post: 08-30-2003, 09:04 PM
