603,899 active members*
2,965 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Linear encoder / glass scale on manual knee LINUXCNC / EMC2
    I'm at the point where my project (http://www.cnczone.com/forums/vertic..._retrofit.html) is functional and I'm looking to make it easier to use.
    First on the list will probably be a pendant / control panel of some sort but I've been thinking about putting some kind of linear encoder on the knee so when I crank it up and down the controller knows where it is. Seem reasonable?
    I'm sure someone has done this before but I searched and didn't find anything.
    Oct 2010
    1189
    Hi i also did retrofit cnc machine.
    I found an arduino based Pendant which i am now improved.
    I am fighting now with cnc threading in the lathe. If you are interested search for handrad AT my page www.tkamsker.AT cu Thomas
  1. LinuxCNC and EMC2 ?
    By bianchi in forum DIY CNC Router Table Machines
    Last Post: 04-30-2012, 02:02 PM
  2. EMC2 (linuxcnc) and turner's cube
    By neity in forum Benchtop Machines
    Last Post: 03-18-2012, 09:36 PM
  3. EMC2 name change to Linuxcnc
    By chester88 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-30-2012, 05:50 PM
  4. EMC2 mesa 5i22 with linear encoder, Does it work?
    By jbcj in forum LinuxCNC (formerly EMC2)
    Last Post: 06-17-2009, 01:19 AM
  5. linear glass scale error?
    By beezerlm in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2006, 05:40 PM
