603,890 active members*
3,964 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Linear length required to rotate table
    Nov 2005
    116
    I need to rotate a turn table to two positions: 0° and 180°
    Due to constraints in the center of the table lifting cylinders, I was going to use two linear pneumatic cylinders to rotate the table.
    I am trying to find out the stroke required to rotate the table 180°. I know the distance from the center line of rotation effects the stroke (farther from center the shorter the stroke) but I don't know what the ratio or formula would be.
    Any help would be appreciated.
    See Attached Sketch for Clarification. The yellow pieces are the two linear air cylinders.
    Aug 2008
    573
    You're not going to get a 180' turn from the cylinders in that arrangement.
    You can turn 180' (or greater) with a single double acting (push-pull) cylinder (think steam train) , or if you want to avoid the potential dead-centre trap, you could use two double acting cylinders mounted at an angle acting on a single crank (think V twin engine).
    Bill
  1. Working out the required length of linear glass scales
    By hotponyshoes in forum MetalWork Discussion
    Last Post: 06-24-2008, 02:03 PM
  2. Ideal length of linear rails for Z axis
    By dex918 in forum Linear and Rotary Motion
    Last Post: 08-31-2007, 07:16 PM
  3. Max length of linear rod?
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 03-06-2005, 03:47 AM
  4. Linear rod+max length?
    By smythe in forum DIY CNC Router Table Machines
    Last Post: 08-31-2004, 02:19 AM
  5. Rotate 3D Profile/Tool length Comp.
    By Kiwi in forum Uncategorised CAM Discussion
    Last Post: 07-09-2003, 11:21 PM
