603,373 active members*
3,733 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Linear rails, rod which is better for cnc?
Results 1 to 10 of 10
    Sep 2003
    10
    I have noticed that a lot of people are using supported linear rod type bearings and a few are using linear rail type bearings.
    Is there any reason for your choice in which type you used?
    Is on type stronger than the other?
    thanks
    Bob
    Oct 2003
    67
    It was all about cost and availability for me. I purchased all Thomson linear rail(rods), some supported and others not. They were readily available on Ebay and the price was right. I would have loved to go with THK bearings but they were a little less available and cost quite a bit more.
    Mar 2003
    2139
    Mostly it's whatever you can get you hands on
    Eric
    I wish it wouldn't crash.
    How do I determine which thickness rods to use?
    Proud owner of a Series II Bridgeport.
    Oct 2003
    81
    With the exception of eBay and surplus bargains, THK style bearings are very pricey. They are also very high precision and can carry amazing loads, but require very accurate installation. Looking at some of the machines on this site, you can see it is possible to build a linear slide with simple materials such as angle iron and skate bearings with excellent results. If you have the money to spend on bearings, I would recommend Thomson style round rails, they have ample load capacity and accuracy, and are easily installed and forgiving of installation errors. (I have seen Thomson continuously supported rails Hilti'ed to shop floors) If you have the money to spend on THK style rails, I would recommend putting that extra money into other areas of the machine such as ballscrews rather than threaded rod, servos rather than steppers, etc... You are building a system made up of many parts, and it will only be as accurate as the weakest one, so spread the money around. This is my philosophy anyway
    Good luck with your project, it will be worth all the time, trouble and expense when you have cut your first part, friends and family might think you're nuts, but we understand
    Steve
    Dec 2003
    25
    I am planning to build my second machine. More accurate this time. Can anyboby tell some address where linear guides are online available. Ebay was not the place. I them to be need at least 1200 mm (47') long.
    Alar
    Oct 2003
    81
    Dec 2003
    25
    Thanks, they look promising.
    Alar
    Jun 2003
    2103
    You might also try here:
    http://www.automation4less.com/linmed3.htm
    turmite
    No greater love can a man have than this, that he give his life for a friend.
    Dec 2003
    383
    THK - type linear rails are just about ideal except for cost, like so many have mentioned. But Ebay is a killer source for these at what can be great prices. The semiconductor industry goes through them like candy for their wafer-processing machines, and since many come out of clean rooms, they are pristine.
    For a typical router, you can really get away with what appears to be a dinky little rail and truck, as their load capacity is pretty large, and when you get into the 25mm rail sizes (like THK SHS25) the load capacity per block is a whopping 8,000 lb! I guess I'm pointing that out to show that many surplus rails/blocks are rejected as "too small", when in fact they are phenomenally strong for their apparent size. Of course, you'll need to mount the rails properly to get a load allowance like that.
    Sometimes, though, the round LM guides are just too convenient. I guess what it boils down to, is "what's available?" and "what's the cost?"
    http://www.thk.com/THKCatalog/THKCat_en/tocf_THK.htm
    These guys will sell online if you got the $$.
  1. How strong? (Linear rails, aluminum structure)
    By WoodSnarfer in forum Mechanical Calculations/Engineering Design
    Last Post: 07-15-2005, 05:29 PM
  2. Max length of linear rod?
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 03-06-2005, 03:47 AM
  3. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
  4. I'm selling a set of linear rails SOLD
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 01-02-2004, 11:13 PM
  5. Alternate Linear Rails??
    By ehiebert in forum DIY CNC Router Table Machines
    Last Post: 10-02-2003, 03:36 PM
