603,818 active members*
4,145 visitors online*
Results 1 to 5 of 5
    CNC Brute Guest
    Linear supported rail source
    Hey guys,
    I'm trying to find the rails similar to Thomson Linear Shafting, but the rails I'm looking for are supported the whole length of the shaft. Not just the ends as on the Thomsons.
    Also does anyone have some deflection calculations on the Thomson shafting?
    Thanks,
    Matt
    Oct 2003
    81
    Hi Matt,
    Thomson makes continuously supported shaft, not just the end supported. All the info you need is available on their website. Here's a link to their linear shaft catalogue. http://www.thomsonindustries.com/PDF...se_Catalog.pdf Other manufacturers of similar shafting are PIC Design, Star-Rexroth, and Nook Industries.
    Good luck with your project,
    Steve
    CNC Brute Guest
    Steve,
    Cool thanks. Unfortunately since I posted I bought Thomson's without supports and some THK rails and bearings.
    I do need some more information on the Thomson's though.
    So I'm on my way to CNC coolness
    Oct 2003
    81
    Hi Matt,
    You can buy the supports without shafts, but you would have to find a good machinist that can drill the case hardened shafts, and you would need open bearings and pillow blocks. You could support the rails on the ends and just use the continuous supports underneath without drilling and fastening the shafts to them. That would solve downward deflection, but not upward or sideways deflection.
    Steve
    May 2012
    If you check out www.nordevx.com they have the supported rails I think your looking for.
  1. Bosch Rexroth linear rail left (Netherlands)
    By Tjippy in forum DIY CNC Router Table Machines
    Last Post: 05-01-2005, 02:06 PM
  2. a cheap linear bearing
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 03-26-2005, 11:52 PM
  3. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
  4. Your advice please on this Linear Rail system
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 10-13-2004, 02:14 PM
  5. Wrong THK rail - Help!
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 07-17-2004, 07:26 PM
