I have a professionally built CNC router, 4x8 foot, in the x-axis travel direction we are seeing discrepancies of as much as .015 inches in feature positions.
At this moment I don't want to discuss the manufactures name to avoid backlash because I am actively working with them on the same issue and not really getting anywhere.
It uses a multi start ballscrew with AC servos with encoders mounted on the servo itself.
These are operated in what I assume is an "open" loop style by WINCNC control PC.
The servos and encoders are connected to servo drivers and that is the only feedback loop I am aware of.
The driver is told to move 16.25 inches and applies what it believes to be the correct number of rotations to the screw to accomplish this.
But when we cut or drill features they are short only in the x-axis by upto .015.
Some features are actually over, see the below example.
I am drilling 3 holes in a pattern that will be used on a part.
Those holes are 7.375 inches apart.
From X 0 to X +14.75
Pair 1 to 2 +.002 to +.004
Pair 2 to 3 -.010 to -.015
Pair 1 to 3 -.010 to -.015
TO the best of my ability to measure the steps per unit in WINCNC appear to be set correctly.
There is no excessive movement in any x-axis or z-axis component when tested with a .00005 DTI.
Used a precision tape measure and vbit, over 58 inches of travel, no discrepency large enough to be visible.
Any tips, or things to check the braintrust here can think of?
