587,594 active members*
4,106 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > list of VF3 replacment parts
Hybrid View
    Jan 2014
    4
    Greetings,
    We just purchased a used VF3. And since we ended up needing to rebuild the drive, while we were waiting we went through the rest of the machine replacing seals, belts and the like. So we are getting a bit of a list of replacement parts that are not sourced through the manufacturer.
    So the question I had is if there was any interest in, first posting the list some were so others could use it. Second if others would like to contribute the info they had gathered.
    The information would be on a spread sheet. And it can be set up with different tabs for different machines, so as to be of use to more people.
    It could be post on a sight that we use to post other spread sheets, which can be set to let anyone both read and edit the spreadsheet. Though that will only work till May when the service is shutting down. But by then it probably would be about done and we could put the file here, or on our web-sight.
    Google Docs has the same thing, but to use or view it you must be a registered user.
    Anyway let me know what you think.
    Jan 2008
    282
    Like it
    thanks
    Lowell
  1. PARTS LIST FOR A CINCINNATI FTV 850
    By joebidwell in forum Machinery Manuals / Brochures
    Last Post: 09-23-2021, 09:22 PM
  2. Parts List once-over?
    By Catmandu13 in forum DIY CNC Router Table Machines
    Last Post: 12-06-2012, 02:07 AM
  3. Parts List
    By Scottjit in forum Daewoo/Doosan
    Last Post: 12-09-2009, 11:26 PM
  4. Arboga G2508 Parts, Parts List, Manual
    By omnimfg in forum Want To Buy...Need help!
    Last Post: 04-03-2009, 05:59 PM
  5. Replacment parts
    By Legion99999 in forum Syil Products
    Last Post: 10-05-2008, 07:27 PM
