587,714 active members*
5,288 visitors online*
Results 1 to 4 of 4
    Jan 2008
    932
    Lithophane box?
    Anyone have experience putting together 'boxes' for lithophane display?
    Or what sort and how much lighting is needed?
    I put one together to test an idea... used white LED's, but obviously not enough of them. And it seems it would need a load of them for a simple 7x5 litho...
    Paul
    Apr 2005
    3
    Cut this out of 6" dia. schedule 40 pvc pipe. Used a 13 watt compact flourescent for lighting. Stays cool to touch even when on 24 hrs. a day.
    Jan 2008
    932
    Very nice. What sort of bit and stepover did you use for that?
    Unfortunately I don't have a rotational arm, so I'm just doing flat stuff, thus the need for a box.
    Apr 2005
    3
    It was cut with a 0.0625 inch tapered ball nose at .15 inch depth of cut (2 passes). Step over was .006 inch. Speed was 100 inches/min.
  1. Lithophane Backlighting...
    By bsimages in forum PhotoVCarve and VCarve Pro
    Last Post: 05-26-2014, 02:25 PM
  2. My 1st Lithophane...
    By bsimages in forum Vectric
    Last Post: 12-28-2013, 06:53 PM
  3. Lithophane
    By Donald in forum WoodWorking Topics
    Last Post: 11-23-2013, 03:44 AM
  4. Another Lithophane- photographic
    By Stewey in forum Signmaking Topics
    Last Post: 01-10-2010, 03:42 AM
  5. Lithophane lighting
    By dmparrott in forum Vectric
    Last Post: 12-12-2008, 11:03 PM
