603,899 active members*
2,861 visitors online*
Results 1 to 13 of 13
    Jul 2022
    24
    Red face LMS 3990 conversion to CNC
    Hi All, have found and read a tonne of great info from this forum since I've recently joined, looking for info on others who have converted this LMS 3990 to cnc, unfortunately most of the links are now dead or do not exist anymore? Companies have closed, or the owners have passed away
    Bought a LMS 3990 several years back and love it. Does what I need it too with the exception of the automation.
    Have scowered around for nearly 1 year looking for an upgrade kit, most had issues with ball-screw length's, custom drilling/machining to get the parts to fit, Companies stating their X2 design will fit fine? leading to their disappearance.
    Working with a company now who does show interest in making this work for me, in return will be available for all in the end. Some design changes are being printed through me for fit and design, when all is 100%...final parts will be sent to me for the actual conversion.
    I hope there is some interest here for this? Will catalogue the conversion step by step for others, list planned electronics, and ask for advice during this on what others think will work best????
    Fusion will be the cad/cam/cnc foundation, looking to use 425oz stepper's with DM525T drivers, Mach3 software, and undecided on the control board(s) at this time, would love some input on something that just flows together and plain works with fusion
    Do want some sort of control at the machine for setup/zeroing/manual adjustments if required??????
    Hope to see some input from your thoughts
    Cheers
    Randy
    Jan 2018
    1516
    Re: LMS 3990 conversion to CNC
    From a bit of experience. I personally think that converting a sieg X2 design machine is like flogging a dead horse. The Z design is a let down, X axis is no better, and the gib setup isn't good. It can be a money pit trying to get it right without getting the end results. That's mostly why the kits are all but done with.
    Most will agree (or have moved onto) the G0704/PM25 size platform, is the way to go.
    It has better travels, twice the weight, stronger spindle, for not a huge amount more money.
    You can also fit double nut screws in them for more accuracy.
    Nema23 motors work best with at least 48vdc, and if they're inductance is 3mh or more. Then 60vdc overcomes it and gives brilliant performace.
    If you plan on a lot of use and saleable parts then my advice is......
    Save your money for a PM25 or bigger. Machine parts for the PM (X,Y) manually on the Sieg.
    Use new PM x,y to then machine the Z parts for it. Then go back and refine the x,y parts on the PM you machined on the Sieg.
    (because the Sieg parts are rarely level).
    That's what I did (my sieg was converted though and I basically got fed up with its design issues). I have still yet to refine my X axis on my PM25 clone. The table has lift on traverse, ball nut housings off the Sieg not were level enough.
    Going from the X2 to the PM was an eye-opener!!.
    theres still lots of room for someone who wants to put out a decent kit for x2 mills .
    Any converted bench top mill/drill is a turd in the big scheme of things but they work and can get the job done if a guy works within their limits and knows how to make them work . The x2 beats the crap out of using a sherline or the other small brands . The key thing is they are mill/drills and they were never designed for heavy mill work
    I had 1 for a hobby machine which was a drill press made butcher job conversion but it worked and it was a cheap conversion , within no time it turned into 4 plus a g0704 . I've since upgraded and they all sit in the corner of my garage , except I'll be setting at least 2 of them back up for prototyping , and the original one will be going into a trophy like show case in my shop . Them little mills can produce some very fine detailed work but they have to be maintained and adjusted every few hundred hours of machining , it's a small price to pay for what a guy can get out of them
    Jan 2018
    1516
    Quote Originally Posted by metalmayhem View Post
    True on the sherline lol.
    I found that shallowish cuts with 8mm was X2 bearable but it wasn't very quick. Did a fair bit of slotting though.
    The drawback I found was that if you used thrust bearings on Chinese C7 screws you could get a wobbly screw due to how it sat.
    The table would pick up on it, leave marks and wear the gib prematurely.
    My STRONG advice is to make your own X axis end bearing plates and Y axis front bearing mount to take 28/12/8 (7001) Angular contact bearings in there. (That's if you use 1605 ballscrews).
    They are mint to use and make a massive difference. (fit them back to back, I think).
    Design could be with a bearing in either side of the mount pressing onto a 3 to 4mm thick central ridge meaning 19-20mn bearing set, then +0.5mm either side for clearance making part 21mm in total.
    Make sure ballscrew shaft machined end to seat the bearing load on is no more than 19mm long to the threads though.
    If you use 1204 ballscrews you can use 10/26/8 (7000) AC but the screws aren't as strong as 1605.
    I use the 12/32/10 (7201) with 1605DFU on the PM clone.
    I think you should roughly get my meaning with this.
    an improperly machined ballscrew will bounce the table , and most chinese off the shelf are poorly machined . I didn't add end supports on the 3 I converted , and I see it as being fairly unnecessary for such short screws . Even my pcnc440's don't have end supports
    The only one I had a bounce on was the 4th that I added a fusion kit to , and I really wasn't impressed . They used good ballscrews it's just too bad they couldn't machine them properly . It more or less left ballscrew marks on the facing op which a few rubs on 400 grit removed , it was very slight but annoying , otherwise it machined well . It wasn't long after I bought that one that I decided to upgrade , so I didn't have a chance to get that issue resolved .
    I had the belt drive kits on all of mine which put the spindles around 4500rpm , and with a 3/8 end mill I ran aluminum at .035" depth at 35ipm while ramping profiles , it was reasonable and the finishes were decent . There's no hogging with them , thats for sure , but they can get the job done
    Jul 2022
    24
    Update, have ordered the cncconversion Sieg x2d kit, had to modify the Z mounts to the head and will manually do this weekend once I put the mill back together from fitting the 3d printed test parts. Now stuck on what motion board to use? So many to choose from, won't ever go past 4 axis, want limit switches, and possibly an air solenoid?
    trying to decide between Mach3 and Mach4?
    Using Fusion for the cad/cam
    Have been looking at these 2 boards:
    https://warp9td.com/ ESS
    https://www.aliexpress.com/item/1005...8da6hlx1d&mp=1
    Stepper motors : https://www.amazon.ca/gp/product/B08...DM55UG43X&th=1
    Drivers https://www.amazon.ca/gp/product/B06...GWISS7BL&psc=1
    Wjat are your thoughts?
    tkx
    randy
    Jul 2022
    24
    Update, Parts are here, control box wiring will get completed this weekend.
    Went with the warp9 Ess and the C25 Bob. 425oz steppers and 860T drivers. 70/12/5 v power supplies.
    Conversion kit looks good, mods milled for the Z mounting, Hope to get it installed first this weekend after i put it back together to mill out a 3" lift for the column. Need the height adjustment now as also went with the tormach tooling and the Z-mount mod cost me another inch.
    They sent weird pully's counts for the Z drive, (22/13) I ordered a 11 to go with the 22 so it will be a 1:2 ratio
    If someone can chime in and throw some experience into how this "ratio" gets setup on the driver settings "if it does" and where in mach4?
    This has been quite the adventure so far, but looking forward to the completion
    Randy
    Jul 2022
    24
    Almost there.... Conversion complete, Control complete, Just checking things out to see if they do what there supposed to do, which brings up first question i'm stuck on and why?
    If I fire up the ESS and load Mach4 all starts fine with the exception of I get a (Z home switch tripped) notification.
    If i hit enable, than disable, I do not get the notification?
    Have checked the wiring and all is fine, all 3 home switches setup the same as NC, lights on the ess pins 11-12-13 are lit, if I trip any of the home switches the corresponding ESS light will go out.
    If it trip any of the home switches they will show as activated,
    I can hit ref all and trip each switch all works as it should ?
    So what did I miss on this ?
    Many thankx for your input in advance, I'm sure to have a couple more
    Randy
    Mar 2023
    Getting ready to (possibly) get into modifying a 3990 myself, and I come here in search of information.
    Have you gotten the last issue resolved and if so, what was the solution.
    Just beginning this adventure and after reading through your thread, I may be entering a rabbit hole I cannot climb out of. LOL
    I mean one user here already has me looking at a larger machine, but I have to be realistic in my budget. ( 2,000 USD )
    Jul 2022
    3
    Cool Re: LMS 3990 conversion to CNC
    There are several important things you need to ask yourself before deciding which path to go down. You've stated a budget which establishes your boundaries. Does that budget include the CNC controller and software, or is it just the cost for the machine itself (not even going to mention tooling here)? How far down the "conversion" path are you willing to go? Looking for the quick and dirty to get some automation... or are you willing to go down the "complete remodel" path for your machine? You mention mod'ing it yourself, are you prepared to custom build all the parts you will need and are you willing to make whatever permanent modification to the machine casting that will be needed (base, table saddle, table, etc...). Are you looking to go full CNC and eliminate manual control? Etc, etc... I mention all of this because I too am going down this path.
    I started designing my build well over a year ago. Spent a great deal of time in the design phase, essentially reverse engineering my design to fit commercially available parts (ball screws, stepper motors, adapters, etc...). Then I started manufacturing the parts. My design went down the slippery slope several times and where I ended up is probably overkill, but it is what it is! :-)
    I've owned an X2 Mini-Mill for 15+ years. One of the decisions I made at the beginning was to start with the latest machine casting (the base, fixed-column, larger table, table saddle, spindle housing and mount). My design requires modifying everyone of these casting except for the spindle housing mount. As I stated above... I took my design over the top... and some of these changes are not necessarily required. Also changing some of the "commercially available" parts (for example: i could have used 12mm ball screws instead of 16mm) might require fewer mod's to existing castings.
    I've attached a couple of design files of my build. Hopefully this motivates to customize your own. It's a lot a fun, a great deal of work and in the end.. it'll be yours!
    Attached Thumbnails Attached Thumbnails X2D Mill Assembly.jpg   X2D Mill Assembly (1).jpg   X2D Mill Assembly (2).jpg   X2D Mill Assembly (3).jpg
    Oct 2014
    30
    A while ago, I also wanted to convert a mini mill to CNC. I started with a Sieg X2D because of the larger table and I found a good deal on a used machine. I purchased plans for an X2 CNC conversion from a YouTuber called CNC4RX7. I was able to modify the plans to fit the larger table size of the X2D. I milled all the components on a PM25-MV I had. I chose a Sainsmart stepper, driver and USB Breakout kit from Amazon. It was reasonably priced with all the motion electronics I thought I would need. I added home switches and used the soft limits in Mach3. I also added a 2" riser block for the column which I purchased from Little Machine Shop.
    It has performed pretty well for my needs (mostly aluminum).
    Apr 2024
    I appreciate how these tips are grounded in practicality and backed by research. Santa Claus Leather Coat, It's clear that a lot of thought went into compiling this valuable resource.
    Jul 2022
    24
    Just an update on the conversion that was completed last fall, machine still working great for my needs, do wish i had a bit more x/y travel, but able to work around that.
    All the knowledge learned building it also helped in the DIY build of a cnc laser that was just completed, its nice to have things dialed in on the first run...
    Next project, A nice size vacuum former. Both cnc mill and laser will contribute to the project.
    tkx
    again
    randy
  1. LMS 3990 / HeavyMetalCNC conversion - backlash problem.
    By t3kboi in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2019, 04:52 AM
  2. Replies: 9
    Last Post: 03-13-2018, 06:00 PM
  3. Replies: 9
    Last Post: 11-12-2017, 09:46 AM
  4. Replies: 0
    Last Post: 03-07-2016, 09:14 PM
  5. Replies: 0
    Last Post: 09-22-2015, 07:05 PM
